KCStudly wrote:So when the triangle between the hub center, rear pivot and axle bow pivot goes flat the spring shackles take up the difference in length? Something has to give.
kd8cgo wrote:Those type or torsion units would work if they are under 6" per side given your requirements, did you get the dimensions before you ordered them? They look longer than 6" from the picture but that can be deceiving.
If you cut those stub torsion axles down, it lowers the effective spring rate and load handling capability. also, if you cut so much off that you lose some of the mounting flange, it can put too much torsional stress on the designed fasteners and steel thickness used in the axle. This also will cause them to try to "pry" themselves off the trailer frame, which can fatigue both the stub axle and the frame, possibly breaking over time. Even just cutting the extra "square" portion off the inside, can cause the torsion action to try to make the square outside tubing "round", because the forces are concentrated over a smaller area.
You can use those type of motorcycle coilovers with the right sprint rate and a trailing arm like your first trailer, instead of the car-size coil springs. I saw you mentioned this and it should work fine as long as you size them right and don't put too much mechanical leverage in the trailing arm, vs. the coil spring rate. You might have to sacrifice some wheel travel to design it right to match the springs, but trailers usually don't need a lot to begin with.
I assume you meant the 6 foot overall width was not including tires and wheels? A 5' wide bed with a 6' wide overall including tires is hard to do using normal axles and wheels! (Without going to a bed-over axle design)
edit: I just had another thought, since you are making a motorcycle trailer. You can mount the guide rails at an angle to each other instead of parallel, in a V shape. This way you can make the rear of the trailer narrower than the front, and mount the axles back further, which will give you more room for your preferred suspension. It shouldn't cause much trouble loading or unloading, as long as the handle bars are above the seat and rear fender height of the bikes. You would have to carefully manage suspension height if you designed it like your first trailer, as putting the axle back much further will make the tongue shoot to the moon when you drop the bed if you have a tall suspension. If you make it low slung enough, it won't be as much trouble.
