McTeardrops wrote:I put cardboard on the work table, got naked, climbed up on the aluminum and cut away!
I guess you have to be extra careful.
I remember your pics, I searched for them but I guess you moved then because they were dead links.
Mark wrote:Good luck, when your done you'll think it wasn't as bad as you thought it would be.
That happens a lot. When I really dread doing something I do all I can to avoid it. When it is done I say, "Hmm, that wasn't nearly as bad as I thought."
s4son wrote:I'm curious how they cut it at the trailer place? Did they use shears or did they run it threough a brake?
As straight and square as the cut line is, I'll bet they used a hydraulic shear. There is no way you could cut something like that on a jump shear, the treadle would have to be like 4ft off the ground to get enough travel.
Thanks for the tips and suggestions! The metal will live in the back of my truck till I can get to it this weekend. Besides, I really don't have anywhere to store it. This week I have to work at a factory across town, it's further away so I'll be driving the Civic anyway.
