Atomic77 wrote:The boats are conducted from Carbon fiber. In my build I'm going to lay Carbon tape on the seams and epoxy the rest. Honestly Mike I won't do it any other way besides spraying it. So I can't be helpful with that. I got hooked into a repair for another team in the pits, where they had rolled on the primer. It was so much harder to prep for paint. Where do you live maybe we could do a clinic?
![Wink ;)](./images/smilies/econ_wink.gif)
I'm in the Denver area, a little too far for a clinic unfortunately. Interesting idea about the Carbon tape on the seams, that thought about using glass on the seams crossed my mind. I work in the furniture industry and know that spraying is the way to go, but my space is limited, that’s why I’m building the way I am. Great info, thanks for the tips.
kayakdlk wrote:If you use 3-6 oz fiberglass cloth with epoxy it will keep the plywood from checking (cracking). You can use the same process as spraying but roll on boat primer/paint if you want a smooth surface (sand between coats). I suggest a two part paint for longer gloss and durability. The Little Swiss build
http://littleswissteardrop.com/thesides.html has a smooth foam roller paint job that looks great. I used his method for my door jamb areas. You can also roll on monstaliner bedliner paint (with no rubber crumbs in the paint) if you want slightly textured extremely durable UV surface. Check out Jeep forms for reviews on Monstaliner durability and check out my build journal for how my teardrop was painted with it.
Dan
I'm going to have some exposed joinery from the half blind box joint I’m going to use and thought it might be interesting to show off the Baltic Birch ply’s. I was hoping to avoid glassing the whole thing, may go the paint route and K.I.S.S. it. Thanks for the bedliner name, I’ll read up.
Mike
