Aussie Off Roader
Re: Aussie Off Roader
Postby Wolfgang » Wed Sep 24, 2014 6:31 pm
124617
Composite panel strip glued to the door frame
Wolfgang
Images: 41
Postby Wolfgang » Wed Sep 24, 2014 7:02 pm
124618
cross section of the edging strip
124619
in situ
Wolfgang
Images: 41
Postby 123jay » Thu Sep 25, 2014 1:23 pm
What are you bending the running boards with?
401/2"X 48" open tailgate bolt together army kit around $450.00
If the world did not suck ,you fall off!
123jay
Postby Wolfgang » Thu Sep 25, 2014 5:25 pm
I have a 55 tonne hydraulic press at work, I bought the bender attachments for it as well..... bit of a pain to change over from punch to bender but I had a fair bit of sheet metal work to do for the trailer so it was the effort.
Wolfgang
Images: 41
Postby Wolfgang » Sun Sep 28, 2014 7:36 pm
124742
124743
playing around with some of the fiddly stuff, mounting tail lights, reversing flood lights and trims to storage areas.
Even though the battery is lying on its side in the photo (and AGM batteries can be mounted anyway you like) it will be sitting up properly when installed... just wanted to see my solar panel working since it was a nice sunny day, so quickly wired it in.
Wolfgang
Images: 41
Postby Wolfgang » Sun Sep 28, 2014 7:38 pm
124741
I rebuilt my rear hatch, wasn't happy with the first attempt. Partially shinned, and hurricane hinge installed.
Wolfgang
Images: 41
Postby Wolfgang » Sun Sep 28, 2014 7:40 pm
124744
I think someone on here asked about my underfloor storage area. This is a shot from the back on one side. Water tank in the middle. I extends about 2/3 of the length. At the front of the trailer the storage area goes the full width separated from this back section.
Wolfgang
Images: 41
Postby 123jay » Wed Oct 01, 2014 12:26 am
Thank you I will have to look in to this.
123jay
Postby Wolfgang » Sat Oct 11, 2014 6:52 pm
125183
Wolfgang
Images: 41
Postby Wolfgang » Sat Oct 11, 2014 6:53 pm
125184
A little more progress this weekend
Wolfgang
Images: 41
Postby dales133 » Mon Oct 20, 2014 3:44 pm
i spied that table edging stuff yesterday while i was out researching parts, what wall thickness do you have and is it on both the frame and door?
is the seal going on the jam or the door?
cheers mate.
are you in Vic too?
dales133
Postby Wolfgang » Mon Oct 20, 2014 8:56 pm
Yep in VIC, factory is in Murrumbeena. I'll take some photo's of the door detail
Wolfgang
Images: 41
Postby dales133 » Mon Oct 20, 2014 9:32 pm
Thanks mate, Geelong here
dales133
Postby Wolfgang » Mon Oct 20, 2014 10:42 pm
125535
closer view of the door trims and seal. The lip is on the inside of the wall, seal is recessed into the door. I ended up using the table top trim on both door and frame.
Wolfgang
Images: 41
Postby Wolfgang » Mon Oct 20, 2014 10:44 pm
125534
125533
rear doors fitted, the lower door on the left is clad in stainless steel and becomes part of the kitchen bench when open.
Wolfgang
Images: 41
