It's been a while since I posted. Life got in the way of fun, plus I caused myself some problems on the build that I had to work around. Then I gave my left index finger a mighty whack so it was unbearably painful to type. It's been so long since I posted, I had to go back and read my last post to find out where I was. I was getting ready to skin the roof and hatch, by the way.
While I was busy with the other so-called "important" stuff, I kept picking away at the build, but nothing spectacular. Until you look at the pile of pix and have to write it all up. So, here goes:
Last time, I was needing some nice bends in my roofing sheets. A company not far from the house named "Custom Sheet Metal" filled the bill perfectly. With a name like that, it had to work. Trading some bucks for some bends and shear cuts got me back on track.
The roof skin is three pieces. I like to call them the "front", "middle" and "back". The front goes in the front, and so on. Pretty cool system, isn't it? The front piece is the one I bent with the 2x4's. It got to go first:
Tuck the bend under the floor with plenty of sealant:
![Image](http://i1315.photobucket.com/albums/t586/capnTelescope/Teardrop/DSCN0339_zpsb92f269f.jpg)
The rear piece has a bend that acts as flashing into the top gutter:
![Image](http://i1315.photobucket.com/albums/t586/capnTelescope/Teardrop/DSCN0338_zps93133a5d.jpg)
The middle piece connects the front and back with EHB (Extra High Bond) tape:
![Image](http://i1315.photobucket.com/albums/t586/capnTelescope/Teardrop/DSCN0336_zps469f0350.jpg)
Word to the wise... If you're going to use EHB tape, clean the metal surfaces with acetone/lacquer thinner/mineral spirits to degrease before you tape.
Stick everyone together, strap 'em down...
![Image](http://i1315.photobucket.com/albums/t586/capnTelescope/Teardrop/DSCN0341_zpsca61b984.jpg)
Add cauls as required...
![Image](http://i1315.photobucket.com/albums/t586/capnTelescope/Teardrop/DSCN0343_zps36999bb0.jpg)
... and let everone get acquainted.
Why did I mention cleaning before taping? I didn't do it, and the front joint failed shortly after removing the straps.
![Frustrated Builder :fb](./images/smilies/angry_hair2.gif)
I pondered that situation, cleaned up the mating surfaces, pre-bent the front piece a little and tried again. This worked better, but there was still a pretty large gap at the front of the middle piece that did not pass inspection.
Third time's the charm... I said to "heck" with the high tech adhesive tape, I'm gonna rivet the damn thing. So I did:
![Image](http://i1315.photobucket.com/albums/t586/capnTelescope/Teardrop/DSCN0360_zps634ec386.jpg)
Note the tab in the foreground.
The other reason the second try failed inspection was that there was unacceptable slack in the front skin piece. I had to ponder the solution for this, and came up with the idea to EHB the tab to the front piece, hook onto the tab with a ratchet strap, and pull hard. This time, the EHB worked as expected of high tech stuff, and the riveting went swimmingly. A plastic chisel from Harbor Fright made short work of the three tabs, and I'm in high cotton. If this fails, I'll go find the 60" wide stuff on a roll and do over like I should have done it in the first place.
At this point, I wanted to put on the corner molding and be done so bad I could almost taste it.
But, like me, you'll have to wait until I finish the next step before that. It's coming right up. Don't go away, the next post is coming in a few minutes.
![Beer :beer:](./images/smilies/beer.gif)
