http://www.fivestarmanufacturing.com/ge ... /DC12.aspx
Might work to take the chill off if you have enough battery.
Or get 2 or 3 K9 bed warmers
tony.latham wrote:I had a similar 12V heater in my Hunter teardrop as those in the catalog (that big one in there sucks 25 amps -that'd take a ten gauge wire to handle it I think). I used it a couple of times and found it a waste of energy. I could hardly notice the heat it put out and I think that's normal for a 12v heater. I switched over to a heated mattress pad. That did work, but found the pad itself to be a bit on the uncomfortable side. In my new teardrop –that's 12v only– I have an electric blanket with a 30/45 minute timer for pre-heating the bed. If I recall it sucks about 5 amp/hours. I think it'll be just the ticket.
120V? I'd need to find a current bush where I like to camp.![]()
Slow: Does that 12V ceramic heater of yours actually make much of a difference?
ae6black wrote:I only use ac for my electric needs. Most of my camping is done in the cold season with a wallmart heater on its lowest setting. If i am where there is no electic I just tough it out with a sleeping bag. Thats always been enough for me. 50 degrees f and up you nomally dont even need a sleeping bag.
Art
