6x12 single axle build with ramp
Postby tbird_1977 » Tue Sep 30, 2014 8:04 am
Would like to say big thanks to all whom have posted their builds and ideas on this board and share my build seeing as I have jumped in both feet. Below is the beginning to where I am at to date 3 weeks in so far.124814124815124816124817
tbird_1977
Images: 9
Re: 6x12 single axle build with ramp
Postby hankaye » Tue Sep 30, 2014 9:46 am
tbird_1977, Howdy;
Welcome to the forum. Looking forward to see what you come-up with.
hank
hankaye
Postby tbird_1977 » Wed Oct 15, 2014 8:54 am
walls and ceiling in. front galley/built in coming next.125320125319125318
tbird_1977
Images: 9
Postby rebapuck » Wed Oct 15, 2014 11:11 pm
Will you be using this to haul "toys"?
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby hankaye » Thu Oct 16, 2014 10:57 am
tbird_1977, Howdy;
Question.
In your initial post, Bottom row of pix, you have, for lack of a better name,
some purlins attached to the wall running horizontally and from what you show
in your second post you secured your interior walls (Beadboard), to them. So,
my question is; Did you fill the extra space with insulation or leave it open?
Also, how thick are your walls now and do you have any windows installed?
Ok, a couplea questions.....
hank
hankaye
Postby tbird_1977 » Fri Oct 17, 2014 4:55 pm
Yes Rebapuck this will be a toy hauler.
Yes hank I filled the gap between the horizontal strips. Started with 1 inch in between the metal studs. Then filled the gap with 3/4 between the horizontal boards. Puts it at 1-3/4 total foam board. Walls and ceiling same system.
No windows at this time
tbird_1977
Images: 9
Postby hankaye » Fri Oct 17, 2014 7:38 pm
tbird_1977, Howdy;
Thanks for the answer. I'm thinking that this may be a good
way to escape from the thermal bridging that a lot of us encounter
with the insulation just level with the wall supports.
Thanks again.
hank
hankaye
Postby tbird_1977 » Thu Oct 30, 2014 1:01 pm
continuing on almost completed. built in cabinet and lights in 125858 and another 125857
tbird_1977
Images: 9
