My first thought was to run the solar wires through the edge of the roof vent's metal flange. That is how the old solar panel was hooked up. But those were much smaller wires, for a 5 watt panel. And that little panel was mounted flat to the roof. The new panel is 100 watts and mounted to a rack something like 4 inches above the roof. The new wires are 10 gauge and 1/4 inch diameter each, not because of high current, but to avoid voltage drop. But since that WAS my plan (for awhile) I figured this is the best time to replace the old rusty vent with the broken fan with a FanTastic vent. But these new wires are pretty stiff. If I ran them through the edge of the vent, they would need to U-Turn real quick like through the fan trim. Which seems like more trouble than it is worth. (On the other hand, I often overpay for trouble, so no big deal).
Instead, I'm just going to pop a hole in the roof, line the hole with some vinyl tubing to prevent chafing and cover with a 1-5/8" Stainless Steel ClamShell Vent $3. (
West Marine model # 180349) And of course goop it up with silicone sealer. Since i can, I'm going to use enough clear vinyl tubing to cover those wires until they are safely up & under the solar panel. No rain will get in the end of that tubing if it was way up there under the solar panel.
Ah progress!
(he says after spending all afternoon getting that little $3 vent cover & some bolts.)
