FoamStream...
Re: FoamStream...
Postby GPW » Fri Sep 26, 2014 5:57 am
pics...
Re: FoamStream...
Postby GPW » Wed Oct 01, 2014 12:35 pm
Oct First , pretty much the Hurricane season’s done . :P Now we can relax a bit and think of other things I'd like to do to the FS...
Replace the rusty springs and add a block to raise it up an inch , although the test cruise had no problems ... Make a nice small partition and curtain for the potty ... add a mirror and small light for shaving. Maybe another little fold out table and small bowl to act as a rudimentary bathroom sink . And add an antenna for TV... Just a small one for the free channels ... news, weather , and how bad the Saints are doing :duh:
And wire the electrical system for a simple solar panel to run ventilation and simple lighting... all wired in the Mini Galley rear wall area ...
And that’s without asking the wife what she wants... ( I dare not !!!) :roll: :frightened:
Having learned the Lesson of NOT to build in the Heat of the summer :sweaty: ... We must take advantage of these “comfortable" days to get all this done .... or started at least ... :thinking:
Ps. I even found some plastic edge moulding to go over the plywood edges of the ribs for a more finished look ... I don’t want to get too silly , just a few nice things , and still with the idea of keeping it Light in mind ... after getting it up to speed on the highway , I don’t want to change the towing characteristics... :D
Re: FoamStream...
Postby GPW » Thu Oct 02, 2014 8:47 am
Today’s pics .... First thing is to give the FS a good cleaning ... Been a wet season , parked under the overgrown Crepe Myrtle tree... mold and mildew have taken hold. :frightened:
Plus my all steel cargo trailer is sinking away ... (plus Filthy) :duh: Fall Cleaning due and soon too ... :roll: Always something to do ... :o
Re: FoamStream...
Postby Mary C » Fri Oct 03, 2014 5:33 pm
My My I do feel your pain. I just sprayed mine with my little water soap and Clorox bottle. I didn't have as much as you but there was some just where I was glueing some canvas and I wanted, to kill it before glueing. I see you have a lot of the black stuff. I find after spraying after it dries there can be a residue left on the surface. Normally I scrub the area off with soapy water and rinse but it is work none the less. I see your sinking trailer may take a little pull to get it out or maybe a big pull. hope you take pictures of the pull. If I was there I'd help.
Mary C.
Mary C
Images: 473
Re: FoamStream...
Postby KCStudly » Fri Oct 03, 2014 8:20 pm
Yeah, if the tires have sunk into the dirt and it has dried around them, you will probably want to dig around them a little with a garden trowel or small spade before trying to yank it out of the hole.
Hard to tell from the pics, but if they are just settled into a depression, or the ground is still soaking wet, then maybe not such a big deal. In fact, if 'in you don't feel much like digging, and the ground is loose enough, you might just get away with soaking the ground with a garden hose to loosen it up before yanking. :thinking: Just thinking (typing) "out loud".
Re: FoamStream...
Postby Olddog1 » Fri Oct 03, 2014 9:19 pm
Might be a good idea to take all that stored beer out of the trailer before trying to move it. :beer:
Olddog1
Images: 15
Re: FoamStream...
Postby GPW » Sat Oct 04, 2014 6:53 am
Not really worried about the mold on the FS m, Spic n‘ Span cleans it well with no trouble ... But I really shouldn’t have parked it so close to that tree (CM) :duh: That tree ... planted it from a tiny twig , now it’s out of hand :frightened: .... pretty , but don’t park anything underneath it for a while ... whatever falls off of it sticks and holds moisture causing a mess , as you can see... We’ve got a brush on a stick, and a pail , so while the weather is good I need to get out there and give it a good wash ...
The inside is basically untouched , No leaks , no problems ... everything just the same as before ... :thumbsup:
The ground around around here, we call Gumbo Mud ... When it’s dry it cracks , when wet it gets mushy... and things sink :o ... for example , the boat wheel sunk halfway on one side and then proceeded to rot right away, the half that was in the wet mud ... gone ... :o I may (or may not) find the same thing when I go to drag the ASCT (all steel cargo trailer) out ... We made a nice space for it under the shed , and since I tried to sell it for so long with no luck , am making it into a storage room for my Fine wood and special tools.. It’s already outside (handy) , and the idea is to eventually turn the shed into a simple wood-shop :thinking: .... a place where I can make a mess and not spend a month cleaning it up...
The idea is to move the FS out of the way (and not under a tree) , then hook the pickup truck to the ASCT ... see if it rolls ... :roll: (fingers crossed)
...here’s a pic of the boat ... you can see the half wheel , tire popped off half rim ... :NC
Ps. Notice the boat is parked under the other Crepe Myrtle ... :oops: You think I’d learn by now ... :duh:
Re: FoamStream...
Postby GPW » Sat Oct 04, 2014 7:04 am
OD, since the Hurricane season is over (touch wood) ... the ballast got used up at several band nights ... :o :lol: :lol: :lol:
Re: FoamStream...
Postby KCStudly » Sat Oct 04, 2014 12:11 pm
I suppose a few well placed patio pavers would just sink, too?
Re: FoamStream...
Postby GPW » Sat Oct 04, 2014 1:51 pm
Oddly enough , anything that spreads out the load doesn’t sink ... as much ... :frightened: :lol:
Re: FoamStream...
Postby GPW » Sun Oct 05, 2014 1:47 pm
Well today was the day for Baby’s First bath .... :o Pulled the FoamStream out , got a bucket with some SN’S and water, and my brush on a stick and started scrubbing ... No problems , everything came nicely clean again without any trouble .... there are a couple of stubborn spots , like where a mud dauber made a nest . have to soak and really scrub that .... but later ... Went quick and the wife helped by holding the hose ... After that I pulled it down the driveway and proceeded to hook up the ASCT (all steel cargo trailer) ... Gave it a little pull .... Nothing .... wouldn’t budge ... so i dug out from in front of the tires , that’s where I saw the tire on one side was flat , so went to get the compressor , filled that one up ... tried again .... Nothing (tire spinning , loosing traction) :thumbdown: Then discovered the other tire was flat also ( both flats hidden in the mud) , and tried to pump it up but had a leak around the rim (tubeless) . Made a lever of a rock and 4X4 and lifted the tire out of the mud enough for it to un-distort :duh: ... And I was able to fill it with air , and it finally pulled free.... Jocky’d that in front of the shed , moved the FS back into its place ... under the tree again , in the Fall ... :duh: :roll: :lol: The wife wanted to wash the ASCT too, but I told her to just leave everything out and we’ll wash it this evening ... ;) (after my Nap) ...
Re: FoamStream...
Postby GPW » Sun Oct 05, 2014 1:57 pm
Oh yeah ... the wife filled in the ruts left by the above process ^ ... Just had to take a picture of that too ... I thought it made a nice picture .... May have to do a painting of that ... :thinking:
Ps. And this time i didn’t park the FS that close to the tree again ... ;)
Re: FoamStream...
Postby bonnie » Sun Oct 05, 2014 5:53 pm
Glad it worked out. Looking good, that Foamstream. :)
Remember, the turtle won. :)
bonnie
Images: 107
Re: FoamStream...
Postby GPW » Sun Oct 05, 2014 6:02 pm
Thanks Bonnie !!!! .... at least we both now know this paint washes OK !!! :thumbsup: How are you doing ??? :D Did you get to camp ?
Re: FoamStream...
Postby KCStudly » Sun Oct 05, 2014 10:23 pm
Doesn't SN'S have an abrasive quality to it? I know it is fine, but I think it has pumice or some fine abrasive. Might dull the paint with repeated use, no? :thinking:
