OK, time to post some updates.
First and biggest is the gluing of the aluminum skins. Walls and roof were glued up using 3M 4200.
Since I have a limited number of clamps, I had to come up with a way to maximize the use of clamps and other ways to hold the aluminum while glue dries. Direction states, 3M 4200 has working time of about 1 hour and dries in 24 hours. The wood frame is there to use with straps. Galley area is held with blue tapes. I was amazed how 3M 4200 initial strength before it dried. Tape was enough for me. Off course my aluminum is 0.040 so it is stiff.
Here is passenger side glued up.
Here are doors.
I tried to have as many item ready to glue up once. 3M 4200 is great glue, but one down side is, once you open, you can't stop. I used one 10 ounce tube for 2 walls and 2 doors.
Then, I glued up roof and tongue walls. Front section of the roof will bend and cover roof of tongue box, so I had to cut and bend that section.
Bending 0.060 aluminum is tough!
It was almost impossible to bend it manually without some kind of heavy duty brake. Not the best job I was hoping for, but I managed to bend it to the angle I wanted. Here is the roof sitting on the trailer. Middle sections are held with 2x4 and clamps, and front and galley area ends are held with screws.
Once glue is dried, I trimmed with router and flush bit. But before I could trim, I had to add some edging so I have a correct profile to trim.
Here is the top of galley wall where hurricane hinge will be attached. There a aluminum edging covering inside, then I added 1/8" aluminum bar on top. I added this because I cut too much off the galley wall.
I will trim flush with this bar, then same aluminum edging will go to cover wall skin.
I also work up sill of galley, too.
I wanted to bend aluminum to cover some areas, but I could not bend aluminum, I opted to use galvanized roof flashing. It looks a bit different from aluminum, but I'm OK with it.
I used 90 degree bend area and opened up the angle to about 120.
Now that I'm ready to trim, I put on my goggles, gloves and long sleeve shirts and went to town. Once I finished, aluminum was everywhere!
I also managed to get one door edged.
Again, I edged interior side first, used the edging to flush trim aluminum skin, then finally add outside edging.
Here is how window and latch will look.
Here is everything somewhat completed.
I screwed up one thing on these doors. (at least one thing I noticed) I for got to add holes for the hinges. I will have to some how find the holes without missing.
That's all for now.
Thank you for following.
