KCStudly, thanks. Yes i had originally positioned the window to look out really. Now it is a compromise between my needs and my wives needs to ease getting in and out. I have filed away in the head about the hinge/handle orientation.
Tony I am doing a half lap join on the skeleton. I was hoping that 2" overlap would be enough as long as I was ready to put the outer skin on as the next part of the process and not handling the skeleton too roughly. It would not be hard to add an extra inch and run it full length but I was thinking light with the strength coming from the skins.
I am planning on putting a fibreglass skin on the outside. It comes in 1500mm widths cut to your desired length. Also it is 1.6mm thick. Thinking it is the same stuff as you see on modern white smooth skinned vans. I am sure it will be significantly lighter than aluminium.
Now to the outer skin. 3mm (1/8) sheets are very hard to join I imagine (never tried it before). I have an issue with sheet size here and I know I will have to do 3 pieces per side, the height and length exceed sheet sizes I can get. I was thinking of again having a join separating the front and the back at the same location as the join in the skeleton. I would then need to have a sheet doing the bottom 3/4 of the front and another sheet doing the top part of the front. I was planning on just butting these sheets up against each other (I will have to extend the location of the skeleton join all the way through). The join on the two front sheets would be at the top of the door height, to maximise what it can glue onto.
I can see on your skeleton that you have left the areas for the bulkheads to go into. I was thinking of doing it slightly different.
- Screen Shot 2014-10-13 at 11.20.53 am.png (97.88 KiB) Viewed 1973 times
In the (quick mock up) you can see the outer wall (dark brown), part of the skeleton (blue), the inner wall (Ply colour) and the proposed cupboard outlines. I was going to shape it to the exact shape of the shelves and then glue it into place so the shelving unit slips into the 3-4mm slots. Perhaps the 3-4mm each side is not enough for cutting errors but I hope I can cut the bulkheads pretty accurately.
With Steve's building method I am still trying to figure out why you need to put any inner skin in place if you are putting shelf units / kitchen cupboards in which will cover the skeleton. I will have to go back and reread though.
