MtnDon wrote:In our cabin wall heater and propane range oven the thermocouple end is in the flame.
where is the thermocuple in a furnace supposed to be to get the pilot light to stay lit? how close to the flame should the thermocuple be. should it be in the flame or beside it?
Are you certain of this? I think you're describing a thermometer not a thermocouple. A thermocouple generates a tiny electric current that is used to hold a gas valve coil open. The net result is the same; pilot goes out, gas turns off.Redneck Teepee wrote:Slow, simply explained, a therm-a-couple is a sealed tube of liquid with a known expansion rate. It has a larger, or bulb end that goes directly into and above the pilot flame for heat, with the other end into your gas valve pilot light port. Let's just say for simplicity, on the valve end of the tube that screws into the valve, it has a little piston that pushes out and opens the pilot gas port, and keeps it open as long as it has a flame to keep the liquid expanded, there fore keeping the pilot lit. If the flame dies, the liquid cools and retracts/shrinks closing the pilot port for safety reasons. Hope this shows you where to look.
Maybe it's a regional thing. Around here, thermocouple only means: [A] device consisting of two dissimilar conductors that contact each other at one or more spots. It produces a voltage when the temperature of one of the spots differs from the reference temperature at other parts of the circuit.pchast wrote:Its the correct term in talking about this capillary that controls the gas
valve on a gas furnace. Yes, your application, Electronics, uses the same
term.
Confusing isn't it...
I'm in North Texas/Dallas area. Here's what we call a thermocouple in these parts: http://www.homedepot.com/s/thermocouple?NCNI-5rowerwet wrote:Not sure where you are, but I can go to my local home depot and buy a thermocouple ( says so on the package) that uses the fluid inside to keep the valve open. I doubt that is very regional as it is sold for gas water heaters everywhere.
warnmar10 wrote:Maybe it's a regional thing. Around here, thermocouple only means: [A] device consisting of two dissimilar conductors that contact each other at one or more spots. It produces a voltage when the temperature of one of the spots differs from the reference temperature at other parts of the circuit.pchast wrote:Its the correct term in talking about this capillary that controls the gas valve on a gas furnace. Yes, your application, Electronics, uses the same term.
We use them on gas fired water heaters, old fashioned gas furnaces, space heaters... pretty much anywhere a standing pilot is called for and no external power supply is available.
