Took a WAG on the door openings and did some cutting today. I used dowels to join the plywood sheets where the hard points are going to be in the galley. I know it costs more for the plywood than using 4/4 material, but I didn't want to cut that many blocks & join all the pieces with screws or dowels. Here's how I do the marking for the dowels. Simple & fast. Plenty strong to hold things in place until the skins go on.
Here's one side cut out and showing the basic profile. I sloped the roof line about 2" to give it a less "boxy" or slab-sided look. The actual panel size is now 46" tall. Add an inch of deck and it will be 47" on the frame. One mistake on this panel, I forgot the "hard point" for the hatch support in the galley. Need to get some cardboard and do a layout now that I have the sides roughed-in. No biggie, I can always add a block of plywood once the point is located.
I didn't have long clamps, so I used two 10' 2x4's, clamps, & folding wedges to pull the joint and put enough pressure on things for the bond. Plenty of force from this setup, quick & dirty but it works.
Here's the set clamped together and ready to rout with a reverse flush cut bit (cutter on the bottom, bearing on the top). Weighed the side once I'd removed all the extra wood. Prior to cutting out the "scrap" it weighs about 85#. Once all the extra wood is gone, it tips the scales at just 17#, much better than a solid panel and plenty strong, once the skins are glued in place. The end closest to the camera is the front, you can see the taper on the top edge to get an idea of the roof slope as it pitches toward the rear hatch. Still have a fair amount of work with the router to do, but we're moving along now. Nice to see some progress and the weather is cooperating. Highs in the 80's now, so work isn't too bad outside now. Summer is finally over, I hope!
