roof rack pics and questions
Postby Aaron Coffee » Mon Oct 13, 2014 8:38 pm
I converted my teardrop to a toy hauler(hauling my nephews soap box derby car)and have been thinking of building a rook rack and would like to see pics to give me ideas. We have some rusty (surface rust with some pitting)7/8 round 14 gauge(.083 wall, if I remember right)at work that I could buy cheap. Would that be strong enough to carry an ez-up and some lawn chairs? I operate a tube laser and tube bender at work so the fabrication part is no problem.
Thanks
Aaron
If I could shut my brain off, I could save myself alot of time, money and effort.
Aaron Coffee
Images: 26
Re: roof rack pics and questions
Postby Redneck Teepee » Mon Oct 13, 2014 10:02 pm
There are many ways to do one. Here is how I did mine.
viewtopic.php?f=21&t=60566 Good Luck! :thumbsup:
Redneck Teepee
Images: 21
Postby Chuckles » Mon Oct 13, 2014 10:45 pm
I had my brother bend up some rain gutter clips and bolted them to the trailer. They fit the Yakima A1 towers for round bars.
124151
Chuck
Chuckles
Images: 48
Postby mary and bob » Tue Oct 14, 2014 6:19 pm
Funny about the soap box derby car. When we bought our vintage teardrop (1946) there were four home made brackets on the roof and two odd looking brackets on each side near the top. We were told that a previous owner had hauled a soap box car on top. The wheels sat in the brackets on the roof and the side mounted things were apparently tie downs. Thule sells brackets that are shaped like a car gutter, I put two on my old Blazer.
mary and bob
Postby Aaron Coffee » Tue Oct 14, 2014 7:46 pm
I also have access to sheetmetal in thicknesses from 20 ga to 1/2" and brake presses. Thinking of making my own brackets(probably out of 1/8 steel) to attach at the side and the top(if I can figure out where my roof studs are).
Thanks
Aaron
Aaron Coffee
Images: 26
Postby len19070 » Wed Oct 15, 2014 5:28 am
Heres 2 similar ones I built. Made from 3/4" EMT and Cedar slats.
Happy Trails
Len
len19070
Images: 24
Postby Aaron Coffee » Thu Oct 16, 2014 7:08 pm
Len,
Thanks for the pictures. At first I was thinking of making more of a safari basket type roof rack, but after seeing yours it looks to be easier to build. How are the wood strips attached?
Thanks
Aaron
Aaron Coffee
Images: 26
Postby len19070 » Thu Oct 16, 2014 8:46 pm
Aaron Coffee wrote:Len,
Thanks
Aaron
I was going more for looks than function so I attached them fro screws from the bottom.
But as it turned out that was the best way to attache them. the slats were 1/2" and the screws went in without popping out of the top (a ruler helped) and as it was situated, the slats didn't fall UP! lol
I've carried a 16'canoe on these racks with no problems.
Happy trails
Len
len19070
Images: 24
Postby 123jay » Thu Oct 16, 2014 10:09 pm
Lin. How did you weld the EMT?
401/2"X 48" open tailgate bolt together army kit around $450.00
If the world did not suck ,you fall off!
123jay
Postby len19070 » Fri Oct 17, 2014 5:59 am
123jay wrote:Lin. How did you weld the EMT?
I have a little welder I got at Harbor Freight.
It was a bit of a PITA.
If you try it though blow a fan on the metal away from you as the EMT is Galvanized.
Happy Trails
Len
len19070
Images: 24
Postby Corwin C » Sat Oct 25, 2014 11:23 pm
Happy Trails
Len
You can also weld EMT with an Oxy-Acetylene torch and mild steel filler rod, grind off the zinc coating beforehand to avoid most of the fumes (still error on the safe side and provide plenty of ventilation.)
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Postby 48Rob » Sun Oct 26, 2014 4:24 am
Copper is easy to work with if you don't weld...you do have to sweat a little though :R
Easy enough to dry fit, then sweat (solder) together.
The feet sit over and are screwed to the spars, and the slats are simply screwed to the tubing.
Rob
48Rob
Postby Redneck Teepee » Sun Oct 26, 2014 8:26 am
[quote="48Rob"]Copper is easy to work with if you don't weld...you do have to sweat a little though :R
Rob
I like it! :thumbsup: That design actually fits this little trailer very nicely. Just keep in mind, to preserve that bright shiny copper look, you would have to clear coat it after you are done or you could paint it the color of your choice, other wise it will surface corrode/oxidize.
Also before applying any coating you will have to be sure and completely remove the soldering acid residual with water and a soft brass wire brush
To get the maximum stiffness and support out of it. you would also use type "K" copper, it has a thicker wall and would be more ridged.
Redneck Teepee
Images: 21
Postby Vedette » Sun Oct 26, 2014 10:40 am
Rob
That is a real work of art! :thumbsup:
Well done!
I really do appreciate it, as I am the worlds worst when it comes to soldering......always get things to hot and have the solder running everywhere except where it should go!! Must not have been paying much attention that day in shop class. :twisted:
Good Roads
Brian
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby working on it » Sun Oct 26, 2014 11:29 am
48Rob wrote:Copper is easy to work with if you don't weld...you do have to sweat a little though :R
Rob
Looks great; complements your paint scheme. If anyone is going to try to copy this, be sure to use type K or L pipe, type M will probably bend. I know from limited experience; I use Pex now. Not sure if Pex would be good rack material, though....
173193172890148599
working on it
Images: 457
