My question is if I should coat the whole thing with a poly mix before applying the canvas?
I'd like the extra waterproofing penetration the mix would give, but don't want to decrease the hold of the glue holding down the canvas.
Thx
LarryJ
48Rob wrote:I'm with Doug.
Though I'm a fan of sealing wood, there doesn't seem to be any advantage to pre sealing the wood, and then applying sealer (glue) over it.
Roughing up the raw wood will help give it a better grip, and penetration to some degree.
Good plan with the test pieces![]()
I'd do the same, gluing canvas to scrap wood (same type as your trailer) and determining how good the bond is roughed up verses smooth, and how well it adheres to any filler.
Rob
aggie79 wrote:... You may find that for covering that large of an area, if you apply glue directly, the porosity of the plywood may cause the glue to flash set. In Texas, in the heat of the summer, I have used a two-step glue process to combat that. The first step is to apply a light coat of glue thinned with water. (I usually cut it 50-50.) Then apply 100% glue over the thinned coat. This way will give you a little more working time.
48Rob wrote: Attention to the most minor details is the key to success.![]()
Rob
