OverTheTopCargoTrailer wrote:Hey chilly willy
If you gonna do -50C you better get a BUTT LOAD more insulation bro![]()
Because with 1.5" white foam ur gonna freeze your chilly willies off
Unless your kicking out 75,000+ Btu per hour.
I have 3" solid inches of blue board and wouldn't DARE TRY TO do -50C
At that temp I'd wanna have 3 chambers inside of each other.
I did my ceiling with 2 x 3" and R19 denium & 3/4" blue board over 4" thick.
Cheers OTTCT
Chilly Willy wrote:Could be difficult to stealth camp in this thing, the color doesn't blend with anything.dustboy wrote:You should be able to make a comfy little house out of that! Although with all the insulation you'll need you might not have much space left!
The insulation was the reason behind going with max width, space disappears quick.lrrowe wrote:Given both the CT's and TV's age, they look in very good shape. That is from what I can see in these photos.
Good luck with your project.
They are in surprisingly good shape. Combination of patience, research, luck, and lazt minute panic payed off.
Rainier70 wrote:I would put that propane cylinder in a propane locker that has a vent in the floor. Just to be on the safe side.
OverTheTopCargoTrailer wrote:Chilly Willy
Don't worry I break all the RULES too !! -
its just that you should REMEMBER if you get a leak of gas and blow up & are unlucky enough not to die
while burned to a crisp over 90% of your body - its a bitch !!
Besides that it may only be LEO crawling up your butt with a ticket if he's inspecting your rig on the road
