Having arrived home from our first trip it is now time to finish off the galley and the headboard cupboards, put the inner liner in the hatch and a few other odds and sods.
I had given up on the idea of trying to fit the BBQ complete with its folding stand attached, in under the galley bench, as it was just going to interfere with the rest of the layout.
So I took it off the frame and it stows against the wall.
- 2013-11-02 18.42.06 (640x480).jpg (238.88 KiB) Viewed 2708 times
There is usually some sort of table at the camps that we can use.
- 2014-09-13 18.02.58 (640x480).jpg (161.25 KiB) Viewed 2708 times
We had some more of the metal drawer sides with the runners and rollers, that we got from a local Emporium, only $5.00 per set, elsewhere they are about $20.00
These make it a really easy job as you only need to cut a ply bottom and back the width you want, fit a nice front, put the runners on the walls. For the fronts I used offcuts from the ACL exterior cladding with NZ Kauri timber surround, and fitted magnetic catches to keep them shut.
Dale found these wire baskets in a storage supplies shop and they are ideal to screw up around the walls in the pantry cupboard instead of making shelves. Quick easy and they don't weigh much.
