My first Teardrop Build
Postby Dobrodoc » Sun Nov 23, 2014 11:48 pm
I started building a 4x8 teardrop using Big Woody's plans late in October. I purchased a "red trailer" brand trailer as the company is nearby. I chose the 4x8 because of the fear of slicing dicing and splicing plywood for a 5x 10 build. Will post pics once I figure it out. Thanks ahead of time for any help advice etc,. :D
Dobrodoc
Re: My first Teardrop Build
Postby Dobrodoc » Mon Nov 24, 2014 12:00 am
Heres a link to my Facebook page documenting my build.https://www.facebook.com/Russteardrop
Dobrodoc
Cut the door openings too big!!!
Postby Dobrodoc » Sat Nov 29, 2014 10:55 am
Anyone else do this? Wish I knew which thing to trace, door vs aluminum inset piece?
Dobrodoc
Postby Dobrodoc » Sat Nov 29, 2014 11:02 am
Here's my attempts to resize the cut outs. The sides were 70$ a piece so I can't start over, not to mention five coats of polyurethane
Dobrodoc
Postby Dobrodoc » Sat Nov 29, 2014 11:03 am
Another pic
Dobrodoc
Postby KCStudly » Sat Nov 29, 2014 8:32 pm
I'm sure you're not the first.
The difference between a novice and a true craftsman is how well he hides his mistakes. :thumbsup:
Postby Dobrodoc » Sun Nov 30, 2014 12:47 am
Well I sure hope the flange will cover up most of it
Dobrodoc
Attached the walls today!!
Postby Dobrodoc » Sun Nov 30, 2014 12:54 am
Here's a pic
Dobrodoc
Postby Dobrodoc » Sun Nov 30, 2014 12:56 am
More views of the side
Dobrodoc
Postby Dobrodoc » Sun Nov 30, 2014 12:57 am
Level clamped vertically on the side to check for plumb. iPhone level worked well too
Dobrodoc
Postby Dobrodoc » Sun Nov 30, 2014 12:59 am
Still more
Dobrodoc
Postby Dobrodoc » Sun Nov 30, 2014 1:02 am
View of the screws into the ply and then the 2x4 of the deck, (after laying a thick bead of premium loctite adhesive)
Took forever to get the glue out, even with pneumatic caulk gun! Must be the temp, 50 degrees in garage with propane Hester.
Dobrodoc
Postby Vedette » Sun Nov 30, 2014 3:04 am
Looks like you will be ready for spring at the rate you are working! :thumbsup:
Keep up the GREAT work! :applause:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby Dobrodoc » Wed Dec 03, 2014 11:16 pm
Thanks! The electric has me a bit befuddled but I'll get some help
Dobrodoc
More pics
Postby Dobrodoc » Wed Dec 03, 2014 11:26 pm
Got the galley shelf in tonight and most of the spars. Got my power center in the mail, don't know what I'm doing!
Dobrodoc
