So since the weather is getting into the low 50's here during the day I have been able to do some Foamy work.
I went ahead and opened up the door clearance to 1/2 inch. This will give me a 1/4 inch clearance around the door to play with now instead of the 1/8 I was looking at before. Once flashing, canvas and paint are applied I hope it will be tight but no binding.
- Door fitment
- DSCF3297 s.jpg (129.41 KiB) Viewed 1692 times
My plans originally called for the window to be in the doors, but I began to think that mounting them in the body was going to be better. The sleeping arrangements are different in this foamy than most TD designs by us sleeping with our heads near the bulkhead rather than the front wall. I figured that it would be more convenient to have the window near our heads especially if we are using the bulkhead as a backrest when hanging out in the trailer. After test fitting the window clamp ring on the door and then on the body I found that yes it was a better place. So to be a little different, which I like to be, I began the task of mounting the window.
So now that I have windows I know how big to make the cut out. I was not sure what size I was going to wind up with so I had to put this on hold till now. These window came with the interior clamp ring so I was able to use that as a template. It was easier for me to find reference points inside so I started there. It could be used the same way on the outside since the clamp ring is the same size as the window. Once I found where I wanted it I then traced along the outside edge of the ring where it goes through the wall.
- Window clamp ring
- DSCF3299 s.jpg (154.16 KiB) Viewed 1692 times
This gave me a nice line to follow with the jigsaw.
- Window outline
- DSCF3300 s.jpg (146.63 KiB) Viewed 1692 times
