noseoil wrote:You might add a shim to push the tracks back from the face frame a bit more for more clearance (1/8"?).
noseoil wrote:Did you pre-finish the wood first?
noseoil wrote:Was contact cement used for the adhesive?
capnTelescope wrote:Did a quick mockup of Hinge 3.0. Results are very promising.
I'm now getting a much better open angle. I may not have to worry about bumping my head, now.
This design works because the hinge has a deeper throat. BTW, Deeper Throat is now a serious finalist in the Name This Teardrop contest. I wonder if I can get that on a license plate? DPRTHRT?
Thanks for stopping by!
noseoil wrote:We used contact cement (fast bond 30 ...)
Ron Dickey wrote:you have had fun building this one.
Ron Dickey wrote:I was however surprised that you reinforced with metal the arches but not the two sharp angles where all the weight is held.
Ron Dickey wrote:How will you keep it from getting higher other then the design of the hinge?
capnTelescope wrote::P
You can do it Tom!
capnTelescope wrote:Hey Tom,
Any prospects out there? I read somewhere that around the holidays is a good time to job hunt, because the competition isn't as bad. I'm squeezing for you.
Users browsing this forum: Google [Bot] and 18 guests
