Source for 5 wide aluminum.
Postby Modstock » Mon Dec 08, 2014 7:28 pm
I need to find a source for 5 foot wide aluminum . Cant seem to find anybody in Utah that can get it . :x
Its gotta be white on one side.
Modstock
Re: Source for 5 wide aluminum.
Postby Redneck Teepee » Mon Dec 08, 2014 7:44 pm
Might try some of these.......http://www.thomasnet.com/search.html?wh ... &supptype=
Even a mom and pop sheet metal shop should be able to order a sheet, or sheets in from their supplier, as they get shipments from the big suppliers on a regular basis. Just a thought. :D
Redneck Teepee
Images: 21
Postby Rolly » Sat Dec 13, 2014 12:57 am
Have you tried Affiliated Metals?
Gary
Rolly
Postby Modstock » Sun Dec 14, 2014 9:34 pm
Yes and they told me this. You can find Mill finish in 5 wide pretty easily at metal supply shops but ....you cannot find 5 wide in painted (white) sheets. Im told they only come in 49 inch. Yes I said 49 inch.
BTW; What do you use to glue your aluminum panels to the wood ??
Modstock
Postby Rolly » Wed Dec 17, 2014 2:58 am
I have used 3M 77 and 80 to stick aluminum to vertical trailer doors. In a previous life I installed vinyl tops on cars. The principles carry over, but some of the techniques don't. We are both in the same town PM me, I'll show you what I have done.
Gary
Rolly
Postby len19070 » Wed Dec 17, 2014 8:45 am
Check with a Local Sign Maker who makes Metal Lighted signs.
Thats where I get mine. Very reasonable and NO SHIPPING cost.
Happy Trails
Len
len19070
Images: 24
Postby tdprice54 » Sat Dec 20, 2014 8:46 am
If you folks will check with a tractor trailer repair shop they carry what they call " Plymetal". It has the aluminum attached to the plywood. It comes in 1/2-3/4 inches sizes. The trailer companies use for their doors. It comes in White and aluminum colors. I'm sure you might could even order a differant color if you have the money. Not sure on the price,but briefly worked at one of these stores years ago.
tdprice54
Postby Rolly » Mon Dec 22, 2014 2:34 am
Check with Utility trailer on west 2100 south. They may have wide white aluminum but it may be thin.
Gary
Rolly
