6x12 V-Nose Build
Re: 6x12 V-Nose Build
Postby lrrowe » Sat Dec 13, 2014 10:03 am
That's the way to find deals. Wish i could find more of them.
Bob
lrrowe
Images: 439
Postby abqlloyd » Sat Dec 13, 2014 3:26 pm
The cheap option won't work as I can't find a box. The top option works better as I can simply drill a hole and slide it in. I have a roll of butyl tape. I will add plastic box cover on the back as a rust-proof spacer to give a little more room in the plastic box.
abqlloyd
Postby abqlloyd » Sat Dec 13, 2014 3:27 pm
Hole saw will make install easy.
abqlloyd
Postby abqlloyd » Sun Dec 14, 2014 4:20 pm
Snow and cold today. Good day to clean out the garage.
abqlloyd
Postby abqlloyd » Sun Dec 14, 2014 5:07 pm
Anyone had any experience using one of these as a solar disconnect?
abqlloyd
Postby abqlloyd » Wed Dec 17, 2014 12:00 pm
Abq to Oklahoma City. Averaged 11.5 mpg towing trailer and about 1000 pounds.
abqlloyd
Postby abqlloyd » Fri Dec 19, 2014 11:52 pm
My observations from 2500 miles of driving so far:
Queen bed will take up too much space in a 6x12. It seems ok on paper. Twin mattress and a fold-out bunk makes more sense for my liking
Counter space. Can't have enough when stopped.
Shower would be nice. Maybe a pan and place the Thetford inside when traveling.
Heat. Must have heat. The noise from a squirrel cage would be preferable to cold.
Saw a guy running a Honda EU mounted in the back of his truck under a slick bed cover made from aluminum channel and FRP. Keeps the noise down and the generator protected. This guy does network maintenance and lives out of his trailer / workshop. A 7x16. Roof mounted AC unit, a couple of windows. He hadn't heard of this site but had a nice conversion. He stays at Walmarts and truck stops unless he's in the boonies. He heats with electric only.
His other big tip was leveling jacks. He has four, and uses his drill to level the trailer in a couple of minutes. He said there was nothing worse than sleeping even a little off level.
Water: I used five gallons since Tuesday. Finding water on the road seems to be pretty easy.
abqlloyd
Postby hankaye » Sat Dec 20, 2014 12:10 am
abqlloyd, Howdy;
Personal experience, if you can't get level sleep with head on the higher side.
hank
hankaye
Postby abqlloyd » Sat Dec 20, 2014 12:14 am
If money wasn't an issue and I had a little more room I think this would be the perfect solution -
Just mount it under the floor and put some sound deadening material around it.
abqlloyd
Postby abqlloyd » Sat Dec 20, 2014 12:16 am
Hank,
Good advice. I've followed that rule for years.
abqlloyd
Postby abqlloyd » Sat Dec 20, 2014 12:21 am
Other notes:
I like coffee. A lot. An on-demand genset would make running the Keurig easy.
abqlloyd
Postby abqlloyd » Sat Dec 20, 2014 12:25 am
Other notes:
abqlloyd
Postby Masterplumber » Tue Dec 23, 2014 12:34 am
abqlloyd wrote:Anyone had any experience using one of these as a solar disconnect?
I haven't installed my complete solar system yet, but when I prewired mine I just used a small breaker box and breakers designed as an ac disconnect for a house. Plenty big enough without taking too much space and readily available at Home Depot and Lowes. I do like Blue Seas stuff though and used one of their panels for all my low voltage circuits - top quality.
Masterplumber
Postby abqlloyd » Sat Dec 27, 2014 9:45 pm
What's the difference between using one of these indoors with a window cracked and a basic Coleman propane stove with the window cracked?
Both burn oxygen.
I've read the manual for the Atwood stoves and they have a CO warning.
For limited cooking with adequate venting is there really a difference?
abqlloyd
Postby hankaye » Sun Dec 28, 2014 12:31 am
abqlloyd, Howdy;
Unless you recess the fixed cook tops and have a cover for it then you'll loose some counter top space.
With the Coleman style you clean it off, fold it up and put it away till the next time you need it.
Both burn propane and create nasty gas that will do you harm... so in that respect they are the same.
hank
hankaye
