PA Wilds 16 x 7 x 7 Bug Out Aluminum Trailer
Re: PA Wilds Bug Out Trailer 16 x 7 x 7
Postby outsidezion » Sat Dec 13, 2014 4:04 pm
Also, built and installed the main bed platform.
Main bed.jpg (102.89 KiB) Viewed 3258 times
Main bed 2.jpg (90.8 KiB) Viewed 3258 times
Main bed 3.jpg (95.01 KiB) Viewed 3258 times
PA Wilds Bug out Trailer 16 x 7 x 7 Aluminum: http://www.tnttt.com/viewtopic.php?f=42&t=61833
outsidezion
Postby outsidezion » Sat Dec 13, 2014 5:45 pm
Gate latches seem to work well for now holding the drop bunks to the wall. Will they hold in bumpy transit? I will lock with a carabiner but not sure how much force they are being subject to.
Bed Latch.jpg (89.75 KiB) Viewed 3243 times
Bed Latch 2.jpg (101.42 KiB) Viewed 3243 times
outsidezion
Postby outsidezion » Sat Dec 13, 2014 5:51 pm
Re-used our big Cabela's Camp Kitchen: http://www.cabelas.com/product/Cabelas-Deluxe-Campers-Kitchen/715223.uts
Cabelas camp kitchen.jpg (87.63 KiB) Viewed 3243 times
Gonefishin''s setup has been my inspiration: Simple, light, happy and care free. The trailer must retain its original cargo capacity for 5 kayaks, 5 mountain bikes, and 2 not very small German Shepherds.
I also will be installing the hot water heater: http://www.eccotemp.com/eccotemp-l5-tankless-water-heater-w-flojet-pump-strainer/
And, again, a nod to Gonefishin', the Dickinson Marine Propane heater.
outsidezion
Postby outsidezion » Sat Dec 13, 2014 5:57 pm
Which leads me to next weekend's project: where do I install my Dickinson Marine heater?
Center, roadside, close to the floor:
Center, road side.jpg (99.46 KiB) Viewed 3241 times
Front or Front curbside:
Front, Curbside.jpg (88.64 KiB) Viewed 3241 times
Or Center, curbside, below the window (and what problems would that cause?):
Center, below window curbside.jpg (100.82 KiB) Viewed 3241 times
outsidezion
Postby outsidezion » Sat Dec 13, 2014 6:04 pm
abqlloyd wrote:Better patent that design. Pretty ingenious.
Have had plenty of time to prowl the forum to conglomerate ideas. :)
I researched the sizes of ship and submarine quarters/berths and decided that we could just barely pull off the triple-bunk. Some berths are actually smaller than these vertically. We (my wife and I) are not very big folks and our kids aren't either. I could sleep on one of these bunks with little reservation.
The triple bunk was the main reason we went to a 7' interior. Without the triple, the whole plan fell apart (ability to carry 5 kayaks, 5 mountain bikes, and all the accoutrements.)
outsidezion
Postby outsidezion » Sat Dec 13, 2014 6:09 pm
Also, a question on getting the propane hose through the floor: I need to drop two hoses, the Dickinson Marine and the cook stove. I want to pull the hoses during travel so that they don't weather and prematurely wear. What type of portal can I drop into the floor that seals around the hose yet is large enough to pass the regulator?
I suspect that my heater will be in one side and the cookset on the other which is annoying as I have to sink two ports and chase two hoses under the trailer every time.
outsidezion
Postby lrrowe » Sat Dec 13, 2014 7:06 pm
Outsidezion,
Where are you going to mount the hot water heater? Inside? Outside?
If outside, how do you keep the water in the system from freezing at night or while away from the CT?
If I could see me using one, the cost, sure would be lower for me versus the Attwood unit.t
Bob
lrrowe
Images: 439
Postby Rainier70 » Sat Dec 13, 2014 8:35 pm
You've done a great job with your setup so far. Love the bunks!
For my stove I run a propane hose in through a marine fuel port in the floor. When I am traveling I remove the hose both from inside the trailer, as well as off of the tank outside. Then roll it up and store it inside. The port opening is about 1 1/2 inch in dia.
And here it is closed:
It isn't big enough to pass the regulator up into the CT but a 4 or 6 inch marine deck plate would probably be big enough. That is what I used to put my stove pipe through my wall.
Both screw closed, so there is no dust etc coming in. But if you use a 4 or 6 inch opening, you would have to figure out something to put around your hose to close around it to keep mice and cold out.
It is best not to have very much rubber gas hose inside as they do have a possibility of leaking. Marine hoses are better. We discussed it some on Gonefishin's heater install pages. Just so you are aware. viewtopic.php?f=42&t=56858&start=30
Eventually I will put in a more permanent metal gas pipe and connections under my trailer.
Hope this helps some with ideas.
Rainier70
Images: 244
Postby outsidezion » Sat Dec 13, 2014 8:44 pm
lrrowe wrote:Outsidezion,
Bob,
My goal is to keep it simple, no fuss. No complicated hard-plumbed systems. (No freezing :) )
I bought the Eccotemp L5 instant hot water heater. I will probably mount either permanently by the door or in an in-transport location and then hang it by the door and shower just outside that door. I only need a 5 gallon bucket or any type of water source. I'm sure you've seen these in action: https://www.youtube.com/watch?v=JmqAM6azSm8
The hot water heater won't freeze as there is no water in it unless the pump is running.
I'm coming from a backpacking background and also an overland style of camping so the basic amenities in a fully enclosed cargo trailer feels luxurious.
My last trailer was an overlander from South Africa:
P7300006 (640x480) (640x480).jpg (131.25 KiB) Viewed 3203 times
Rear 2 (640x480).jpg (106.79 KiB) Viewed 3203 times
outsidezion
Postby outsidezion » Sat Dec 13, 2014 8:47 pm
Rainier70 wrote:For my stove I run a propane hose in through a marine fuel port in the floor.
Cindy - I think you nailed exactly what I what to do. Now I know what to look for. THANKS!
Nate
outsidezion
Postby lrrowe » Sat Dec 13, 2014 9:32 pm
Thanks outsidezion,
I believe I understand what you are doing. I may need something a little more permanent. But I will be watching your progress with much interest.
Bob
lrrowe
Images: 439
Postby Rainier70 » Sat Dec 13, 2014 9:32 pm
They are called a deck fill rather than fuel port as I said. Here is a link to one on Amazon
http://www.amazon.com/gp/product/B000Y8 ... UTF8&psc=1
Rainier70
Images: 244
Postby outsidezion » Tue Dec 16, 2014 4:25 pm
Rainier70 wrote:They are called a deck fill rather than fuel port as I said. Here is a link to one on Amazon
Got them ordered, Cindy. Thanks!
outsidezion
Postby NO David! » Tue Dec 16, 2014 6:28 pm
How did I miss this one???
Nice build, really like those ATC trailers, Gonefishin a hero of mine as well. Kayaks, kids, mountain bikes, very familiar. 7x16 was the ideal for us as well.
You may have viewed our build already, but if not:
http://www.tnttt.com/viewtopic.php?f=42&t=48345
We used the removable bunks to hold kayaks as well as the super handy vertical e-track (ugly but really functional and modular):
I think Gadgetman built a neat removable PVC pipe kayak rack as well, somewhere around here...
PVC bike rack is really handy inside and outside the trailer:
Basic plans here:
http://www.utahmountainbiking.com/goodies/TruckbedBikeRack.htm
Not too late for some vertical e-track for you: (a page or so down...)
http://www.tnttt.com/viewtopic.php?f=42&t=49766
This cargo conversion idea has been huge hit with our family, and really handy even for day trips, it's really not overkill, everything is pretty much loaded already, and there when you need it after a day of paddling or biking. We just unload whatever sport or hobby we aren't doing that trip, and presto!
Looking forward to you marine heater install.
Best,
David
NO David!
Images: 37
Postby outsidezion » Thu Dec 18, 2014 9:13 am
NO David! wrote:You may have viewed our build already, but if not:
I'll check out your build when I get the chance, David. It looks like you have been down the road I am headed. Haven't figured out the bike transport scenario as one of my goaIs is to avoid "the dance" of set-up and take-down having done the pop-up camper and roof-top tent overland trailer option in the past. In other words, I want to back into our spot and be out on the water or the trail with no fuss with the essential including beds and bedding and kitchen supplies and food pretty much ready to go. It makes it easier to get out on a weekend amongst a busy life.
I will be checking out the e-track: I'm envisioning a fork-mount bike rack (5) mounted across a 2x4. Front wheel has to come off but not too much effort beyond that. It all depends where the major build components end up in terms of interior placement.
Hope to get some time on the trailer this weekend.
Nate
outsidezion
Users browsing this forum: onehoser and 7 guests
