120V External Outlet
Anything electric, AC or DC
Re: 120V External Outlet
Postby abqlloyd » Sat Dec 20, 2014 12:36 am
Walmart has a kit with a cover, box, and receptacle for $10. Flush mounted.
abqlloyd
Postby lrrowe » Mon Dec 22, 2014 10:49 am
You say Flush Mounted. Does that mean all the box is internal except for the cover? If yes, I might have to force myself to go into WM. Boy that will be a struggle if you know what I mean.
Bob
lrrowe
Images: 439
Postby abqlloyd » Mon Dec 22, 2014 11:53 am
Yes. The plastic box is internal. Cover external.
abqlloyd
Postby lrrowe » Mon Dec 22, 2014 12:07 pm
I will force myself to make the trip and see if I can find it. It was not on their website. Thanks.
Bob
lrrowe
Images: 439
Postby working on it » Tue Dec 23, 2014 9:05 pm
I was intending to mount a couple of waterproof access covers on my trailer: one for park-power input @120vac, the other for external output of the same voltage. I bought a metal box for the input, and was looking for a Marinco for the output, when I realized that I had had several outside outlets fail me over the years, due to bad gaskets or failing to shield a working circuit from wind-driven rain. I decided to mount my plugs/wires inside the trailer, with an expandable waterproof cover protecting the opening and with only an outdoor-rated extension cord exposed to any water.
Tay-mac cover.jpg (15.59 KiB) Viewed 1009 times
My plug-ends are well away from any possible water contact, and my chosen cover will allow two cords(input, output) to be used at once.
  • 123006 waterproof cover, snaps shut, simple hole in wall for running cords
  • 123160 many cord/outlet/GFCI combinations possible
  • 122999 remotely-mounted master breaker
173193172890148599
working on it
Images: 457
Return to Electrical Secrets
