Hi from Colorado
Hi from Colorado
Postby Thommyknocker » Fri Dec 26, 2014 10:50 pm
Thanks for letting me hang out here with ya.
You've certanly gathered a welth of information, i hope to put it to good use this spring.
Ive been lurking for a few months, and I've got time to start my detailed plans.
This fall i rebuilt and welded up my old HF trailer. Its served us well but i want an enclosed trailer to haul stuff behind my hot rod. So the idea is to create a teardrop, and just omit the gally.
DOH my pics are to big, I'll have to resize em.
here is to a happy new year :beer:
Thanks for having me
Thommyknocker
Re: Hi from Colorado
Postby Vedette » Sat Dec 27, 2014 2:18 am
Welcome to the Forum
Always nice to have more Street Rodders! :thumbsup:
You might want to rethink your Galley decision?? :roll:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby Vedette » Sat Dec 27, 2014 2:22 am
How about a TD built from cars? :thinking:
Check out my newly started build Kermit. :twisted:
Build Journal Section
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby bc toys » Sat Dec 27, 2014 8:48 am
welcome to the group and yes you might want to rethink the galley ideal
bc toys
Images: 42
Postby KennethW » Sat Dec 27, 2014 9:00 am
What, You are building a teardrop to go to hot-rod events and leave off mini bar- trophy shelf - galley. You may not miss it ,but it is defiantly a great part of a teardrop.
KennethW
Images: 82
Postby Thommyknocker » Sat Dec 27, 2014 12:51 pm
Thanks guys,
Ive got 2 campers already lol. A 12' popup and a 24' travel
The main goal of this build is to haul my wife's mobility scooter around to car shows.
The trunk of the '50 is packed with just the sun shade and 2 chairs. I'd have room for a cooler and the portable grill with it.
I'm leaning twards stick built with FRP skin to keep it really light
Thommyknocker
Postby KennethW » Sat Dec 27, 2014 1:10 pm
Maybe a dropped floor behind the axle with a tailgate that folds down when you open the hatch for easy loading?
And a turn out grill that would fit over the scooter.
And put the galley on a slide to pull back when the scooter is unloaded.
Just some thoughts. Have fun with the build.
KennethW
Images: 82
Postby Thommyknocker » Mon Dec 29, 2014 5:29 pm
Vedette, Those builds are sweet! I don't want to color sand ever again LOL
Great ideas Kenneth, thanks.
I did add a headboard/shear wall with some storage nooks.
Still thinking of the rear area. I did add a mid-wall brace which I could easily add something to.
I'm still torn between stick built and skeletonizing plywood.
teardrop inside.JPG (55.19 KiB) Viewed 1882 times
teardrop profile.JPG (45.16 KiB) Viewed 1882 times
Thommyknocker
Postby Gold5one » Tue Dec 30, 2014 7:05 pm
Welcome-
I'm also using a HF fame for my build, but with a 6" stretch in front of the axle and welded solid. I was going to build really light, but then I realized that you need enough weight to keep from getting tipsy from side winds and trucker turbulence. I'm using 3/8" plywood for the outside.
Mark
Mark
viewtopic.php?f=50&t=74522
Weekender-XL build journal
sold-2018
Gold5one
Images: 157
Postby KCStudly » Fri Nov 13, 2015 1:41 pm
Just throwing this out there in case it didn't occur to you; you could conceivably have the scooter load thru a side door with the ramp stored underneath ahead of the axle, then build the galley more traditionally. Nice to have an instant horizontal surface to make lunch on or to display that photo album of the street rod build-up.
There was also a TD build on here somewhere where a guy made a forward compartment/locker to transport his para-glider; sorry I don't remember the name of it. It was a little bigger with the full size cabin and galley and the locker in front, but the side loading feature might give you some ideas.
Let me have a look for it... ah, here it is: http://www.tnttt.com/viewtopic.php?p=1096651#p1096651
Postby Thommyknocker » Fri Nov 13, 2015 4:51 pm
Hey, thanks for the comments
Yup, I've considered it, but the big scooter is #300 and 52" long.
Way too much tongue weight IMHO
Worse case I can add it later.
Thommyknocker
