jonw wrote:I used my Kreg jig for pocket screws on mine, plus Titebond III glue. Worked great!
Graniterich wrote:I am using solid 3/4 plywood, any advice on how you applied adhesive to the end of spar and slid in between walls with out wiping it off?
Maybe pull walls apart a touch?
HornD wrote:If you wanted really strong and had the time a dovetail from the top would not be that hard.
You could cut the spars with the tail on one end on table saw (60" up in air is tough) or cut with jig saw carefully then use that for layout on Side Frame.
Now that is a tough joint with plenty of surface area for the Polyurethane glue to bite to
