KCStudly wrote:Sorry you had problems.
SS fasteners can gall and seize very easily. Lubrication is the solution. Anything is better than nothing, light mineral oil, anti-seize, wax.
BTW, SS can be drilled, but it takes a sharp bit and is much more sensitive to using the correct speed and pressure. For drilling out right hand thread bolts, a left hand drill bit turned in reverse is preferred.
A third option for the repair would be to make a small router template, square up your hole, fit a dutchman, put a new thread insert into the dutchman and epoxy the assembly into the routed out hole. Just a thought. Maybe not enough margin to get a big enough block that wouldn't be split by the insert, so maybe filled epoxy by itself would be better; just be sure to wax the inside of the insert (with a q-tip), maybe stick a foam earplug in there to keep epoxy out.
Gold5one wrote:Wow, what a mess with that bolt! I have been bitten by broken bolts and screws so many times in 50 years, that it's not funny. 10 years ago I tried to save some money by changing the leaky exhaust gasket on my Piper Cherokee airplane by myself.- Well I failed to anticipate that the leaking gasket might have compromised the bolt I was removing. It snapped off flush with the aluminum cylinder head- opps! It only took a $2000 for the $100/hr mechanic to R&R those heads. I am no longer involved with aviation.
Wow, I don't have guts to work on an airplane myself, especially if I'm going to fly that later.
KCStudly wrote:Awesome work you are doing there.
You should be proud of those hinge spacers, they came out nice.
tony.latham wrote:Gawd... I sense another retiree! Almost unbelievable. You can't Photoshop craftsmanship.![]()
That damn bolt was a real B@STARD! Two-bits it chewed into a night's sleep or two. Like KCStudly's build log, that scene threw in a bucket of stress like a nail-biting mystrery novel.
Finding those T-nuts with magnets was brilliant!![]()
Perhaps I missed it in your thread, but in looking at your interior, I see something hinged and mounted on sliders. What Houdini trick are you hiding there?![]()
dales133 wrote:Nice work! The only good thing about stainless bolts is they don't rust. Everything else about them sucks!
ryuandwings wrote:dales133 wrote:Nice work! The only good thing about stainless bolts is they don't rust. Everything else about them sucks!
Thank you.
I really didn't know how easily SS screws could strip or break off. I was thinking since it is rust resistant and so hard and expensive, I though that was good all purpose fastener.![]()
Oh well, at least I learned that.
