by 2bits » Wed Jan 07, 2015 1:01 pm
Sounds like I might be in the market for a sandblaster and just use it without a blasting cabinet to get all the paint and stuff off of there... will be alot of sand but worth it. Not sure if that's even possible, I would love bare aluminum on the bottom and the standard Scotty green on top.
The interior is complete but painted in the same horrendous way. When I looked close at the photos, the cabinets are all there and nothing is busted, and there wasn't any rot or separation at the seams of the walls, although roof has extensive git er done repairs. The exterior walls are straight, but the roof is completely unrestorable, there is actually a huge floormat tarred down to keep it from leaking haha.
My plan is to remove the windows, door, trim and entire roof. Throw the roof away, clean and paint the exterior walls to the original style, clean the windows and door and reinstall with new headliner and sheet of aluminum for the roof with no roof vent. the interior should just be a new coat of paint, polishing aluminum trim, installing a bed and table and rebuilding the entire drop floor which is rotten, the rest of the floor seems OK. Walls seems solid too. I'm sure I'll have to rebuild all the roof and front and rear window framing tho when I redo the roof.
I'd like to use this since it is smaller than my Shasta, and sell the Shasta. I also had an idea to make the drop floor into a permanent shower pan. The shower would be powered by a standard kitchen sink sprayer and a long hose, and a shower curtain rod on the cieling that could be stowed. We'll see how that works.
I'll start an official build thread once I get it, I don't think it's too bad for a couple hundred bucks.
- Attachments
- IMG_7871.JPG (108.18 KiB) Viewed 1016 times
- IMG_7873.JPG (126.19 KiB) Viewed 1016 times
Thomas
