Ok here goes. My plan is to build a teardrop worthy of taking into the mountain trails out here in Colorado. I plan on towing it mostly with my wife's 4 door Wrangler, but from time to time it may end up behind my truck. I say this because I am using the same wheels and 32" BF Mud Terrain tires that come stock on the Jeep Rubicon. This way the spare tire on the jeep doubles as the spare for the trailer as well. The overall plan is to have a camper that can be taken into the trails and when we find a place that looks good we can just pull off the trail and stay the night right there. I am planning on a 12 volt power system with a battery for the off the grid camping and for when we stay in more civilized places I will have a few 120 vac outlets and an air conditioner for those really hot days. The profile will be a modified Grumman on a 5x10 platform.
The Frame:
I am starting with a steel frame that was custom built for me by Jayhawk Trailers (a local trailer shop located in Commerce City, CO). With the help of the owner we determined the axle width and trailer construction that I would need for my trailer. To be able to use the Jeep wheels I used a 2" wheel spacer mounted to the trailer hub to be able to clear the dust cap of the trailer hub and use the stock Jeep wheel as is without modifications. The trailer measures 120" x 61" to the outside of the frame for a starting dimension. The fenders and wheel wells were installed by Jayhawk for me and will add a few hurdles during wall construction, but will be a nice flat surface outside of the trailer once it is finished. I wanted a beefy axle to be able to take the abuse of rocks and anything else the trail might throw at it so from Jayhawk it had a 3500# axle on it. I have taken a leaf out of the suspension to derate the axle to be a 2000# axle which should make things ride a little better down the road.
This shows the wheel spacers I used and the blue paint I added to the inside of the fenders.
The Doors I purchased from Frank at Vintage Technologies. They arrived this afternoon and look great! He even made sure that they had the same key for each side.
I started on the subfloor this past weekend and once I get a little farther in the build I will add some pictures of it.
If anyone has comments or suggestions to me please let me know. Enjoy the build of my offroading teardrop!
