aggie79 wrote:I hate to ask a dumb question since, by the evident demonstration of your incredible skills you more than know what you're doing, but have you tried a sample bond of filon to plywood with epoxy? I have very little epoxy experience and no vacuum bonding experience so please take this into consideration. Potential concerns are: epoxy compatibility with filon, having enough "tooth" for the epoxy to adhere to the filon, and "starving" the bond join. (I guess the latter could be overcome by adding "flour" or cabosil to the epoxy.)
Anyway, please don't dwell on my musings. You have a fantastic beautiful build in progress.
I did some research on your concerns...and here's what I have discovered.
-It appears that Filon has very different sides. (At least the Filon that I am getting on Saturday.) The outside is coated with a layer of gelcoat. This gives the exterior a nice finish that doesn't need to be painted. The other side is not gelcoated and unfinished. It has a rougher, more porous texture. There's the tooth we're looking for.
-Regarding the starvation of the bond joint...There's a bit of a trick to getting the right amount of epoxy on the surface...the Lauan tends to want to soak it up a bit. The trick is to get plenty on without going overboard. When I make my vacuum bag, I will have a layer of cotton covering the piece that will soak up any excess that is squeezed out by the vacuum clamp. Viscosity is important and the epoxy needs to be able to flow evenly so thickner is not recommended. But when I do thicken it I always use Aerosil, which is a fumed silica... or on occasion I will also used finely ground cotton.
-As far as compatibility is concerned, I stopped by our local RV dealer and they took me back to the repair shop and showed me a large Filon repair. They patched in a large piece using epoxy, then taped the seams and used epoxy on that side as well.
Thanks for your concerns... they have helped me to further my knowledge of the product!
