slow evening at work tonight, so I'm pondering plans for the trailer (again)...
Thoughts on Electrical:
I'll pick up a simple rv style power center. We'll be boondocking every now and again, and a simple 12V deep discharge battery will be enough for keeping the electronic devices charged and working. For those times when we have shore power, a simple plug mold will more than suffice. I'll do a simple outlet at the nose of the trailer for when we have shore power, but also will put a couple of 12V USB outlets for cell charging. Lighting will most likely be 12V only, with at most a 110 light in the kitchenette area.
Decor
Obviously this is putting the cart waaaaay before the horse... but here I go anyway: I'm planning on light color wood for the spars, which I'm not planning on covering. Still, my idea of 'camp' was imprinted on several houses my grandparents rented when I was a youngster. They had pine with an amber shellac everywhere, so I may put a seal coat of the mix and leave it at that, but I may also put another more 'golden' color as well.
I do know that this is one place I'm going to 'win' the color battle with my wife. I lose at home, but I'm planning on greens and browns for the inside wall panels. I'll be closely copying GPW and putting up the same/similar cardboard to cover the interior spaces. Exterior... our current TV is the blue/purple Escape, but I think I'll let the trailer be its own entity... I'll go with a light grey or tan base with Green and Brown accents.
Doors and windows...
I'm going with manufactured doors for the sleeping area, home built for the tail. Windows.. there's where it gets tricky. I'm leaning as I mentioned towards a pair of screened triangular supports for the lifting roof. up front, I'm considering shop built tilt out casement panels for ventilation. Not windows, but rather panels that will tip out at the bottom with screens inside. Sketches when I have some time at home... I can 'see' them in my mind's eye, but they're not anything I've ever seen. Basically a way to have weather tight solid walls, AND have ventilation in the sleeping area. For privacy's sake I'll be putting these near the top of the wall, and they'll be about 8-10" tall and 15" or so wide.
- ImageUploadedByTapatalk1421817486.046598.jpg (233.54 KiB) Viewed 2166 times
- ImageUploadedByTapatalk1421817467.588940.jpg (254.21 KiB) Viewed 2166 times
[ Really slow night... did a quick 5 min sketch of the tilt out panels and roof raised. Pardon the crudity, just trying to show the panels in all three modes... closed, halfway open and fully open...]
The commercial doors will get curtains inside. The lifting roof will have fixed windows across the tail, with curtains in case the campsite will force us to park where the light would stream in in the morning. I'm a serious night owl, and would sleep in a 'cave' if I could manage it. Lori likes things open and airy, and is a morning person...
