Ned's Grumman 2 (ish) TD in New Zealand
Re: Ned's Grumman 2 (ish) TD in New Zealand
Postby Ned » Sun Jan 25, 2015 9:58 pm
Did some more solidworks drawing today.
Got the galley finished enough to my liking. So big counter top space, and some small drawers down the bottom. That area is only 250mm deep as i want/need leg room for sleeping so cant do much with it. Next to the drawers is a fold out table bit for a cooker or what not, and behind it will be my battery and other 'junk'
I'll use the same size pieces of wood for the inner cabinets. I dont cary many clothes with me etc, so dont need much room in there. Doors are a little higher, and a bit more room but not much. The panel below it will house a stereo and some speakers, as well as all the electronics (bar the battery) and will have a removable face plate to get to all the fuses etc
Build Journal :: My Grumman 2 (ish) TD
Ned
Postby Sheddie » Sun Jan 25, 2015 10:04 pm
Hi Ned,
Good start :thumbsup:
Those 2700 sheets were a good find, are you going much longer than that or will that give you the length you need? That white oak sounds nice, and will make it feel more open inside. With the 1.5 for the roof, have you concedered ACL (alloy composite laminate)? You can get it in 1.5 wide and various lengths, and can put it directly over the frames, no need for the ply, it is self supporting. It comes in a coloured finish or bare alloy, it bends around the curves easily and holds its shape well.
Sheddie
Images: 1129
Postby Ned » Mon Jan 26, 2015 2:11 am
Thanks. I did look at about 6 different manufacturers for acl type stuff but nobody had 1.5 in anything other than white red black or yellow unfortunately, so going with the standard ply and 0.9mm aluminium.
Ned
Postby Sheddie » Mon Jan 26, 2015 3:28 am
We got our acl from ullrich. The one we used over the roof is white on one side and mill (bare alloy) on the other.
We used a 1.5 x 4.8 sheet did the full length over the roof and hatch.
Cabinets look good, you should have plenty of storage in the galley and in the cabin.
Sheddie
Images: 1129
Postby dales133 » Mon Jan 26, 2015 5:26 am
Looking great ned and as Brian said ulrich have mill finish 1.5 wide.
In fact ulrich have far more range there than here
dales133
Postby Ned » Mon Jan 26, 2015 5:41 am
Ullrich only had silver/white in 1.5 when I talked to them last week, and is $317 + gst a sheet. Cheaper to use aluminium and ply...
I was really keen on the composite stuff, but not at that price, and the silver doesn't look like aluminium at all unfortunately.
Ned
Postby Ned » Wed Jan 28, 2015 3:03 pm
Just bought myself some birthday presents from Grant over at Li'l Bear Tag-Alongs!
Hurricane hinge, offset door hinges, molding for the door seals, windows, door and galley latches, drip caps, porch lights and license plate light/bracket.
Not cheap by the time i get it shipped here, and convert to NZ$ though! $1129.98 but still a happy man.
Ned
Postby KCStudly » Wed Jan 28, 2015 3:39 pm
Happy Birthday! :thumbsup:
Postby dales133 » Wed Jan 28, 2015 5:06 pm
Happy birthday mate and I ended up going aluminium and ply for the same reasons
dales133
Postby Ned » Wed Jan 28, 2015 7:33 pm
Cheers guys.
Just got back from TWL to buy some trailer parts, and got me a GOOD deal (for a change)
Friend of mine works for the company and managed to swing cost +10% and ended up paying nearly 1/2 the RRP
750kg springs $34.07 a SET
hanger and slip brackets $5.21
Hub and Stub kit (1500kg, in 4x4.5, same as tow car) $70.17
got some strops as well for $3.44 each (small ones, but 250kg ones, good ones)
thats all excluding GST (15%) but the hub and stub kit alone is normally $134 and my total came to less than that
Ned
Postby Sheddie » Fri Jan 30, 2015 4:44 am
FYI. Ullrich can do ACL in mill 1500x4800 $240 + gst
Sheddie
Images: 1129
Postby dales133 » Fri Jan 30, 2015 4:59 am
That is a great deal wtg mate.shame about the grab snatch and take.
Did they lower income tax when they put it up?
dales133
Postby Sheddie » Fri Jan 30, 2015 5:09 am
Lower tax! :o wash your mouth out! :cry:
Although motor reg is going down soon. :thumbsup:
Sheddie
Images: 1129
Postby dales133 » Fri Jan 30, 2015 6:05 am
Rego here's a bastard.
About 700 a year
dales133
Postby Ned » Fri Jan 30, 2015 8:10 pm
We are going to come down to ~200 a year in a few months :-D
ACC found a few million dollars hidded under a mattress somewhere so now we get to pay less :-)
Ned
