Fold up bed, use wood or steel or?
Re: Fold up bed, use wood or steel or?
Postby lrrowe » Thu Sep 11, 2014 8:17 am
I do not have the welding abilities to make one like this. It does look very simple, clean and functionable. So I will probably do something like Dirtclod did in his build viewtopic.php?f=42&t=53941&start=15.
He used 1/2 in plywood with 1/2 in support rails and is happy with it.
Bob
lrrowe
Images: 439
Postby aggie79 » Thu Sep 11, 2014 10:36 am
lrrowe wrote:I do not have the welding abilities to make one like this. It does look very simple, clean and functionable. So I will probably do something like Dirtclod did in his build viewtopic.php?f=42&t=53941&start=15.
That's a very nice design. I know I read the thread when it was posted but somehow it didn't register. Thank you for reposting it.
Postby lrrowe » Thu Sep 11, 2014 2:58 pm
I suffer from that problem every day. And it does not better with age. :cry:
Bob
lrrowe
Images: 439
Postby AZ_Desert_Rat » Wed Jan 28, 2015 8:20 pm
Hey Bob,
I have been bouncing around and just checking in .... How's those bunks going ... did I miss them or have you made them yet and if so, were they wood or steel ?? :roll: :roll:
Happy Camping & Building,
John (JC)
The Arizona Desert Rat 6x10' Cargo Conversion
The FunFinder a 19' Toy Hauler
An AZ Desert Transplant
Gallery: gallery/album.php?album_id=3168
AZ_Desert_Rat
Images: 55
Postby lrrowe » Wed Jan 28, 2015 8:26 pm
Hey John, welcome back. I have not much since you and I last posted on this. Long story tried to made short is my back keep me down to doing just about nothing? I am on the rebound and starting to pick up energey and speed. I have not build my bunks yet, but when I do, they will be wood. I have the design in mind and I will look for another posters link which I will copy and I will post it here.
Found it.
Dirtclod's project.
http://tnttt.com/viewtopic.php?f=42&t=53941&start=15
Bob
lrrowe
Images: 439
Postby jwhite » Wed Jan 28, 2015 11:24 pm
I built mine out of 4x8 plywood with drop down legs made of shelving pine these photos show it down unfinished and folded up, I also have a drop down shelf,
77611776076655364427
jwhite
Images: 46
Postby chiefb711 » Thu Jan 29, 2015 1:20 am
CGRotorhead wrote:Good question I have been having the same dilemma :x
Use aluminum...it's five times as expensive and just as strong. The weight makes up for it all though. I got mine at a salvage yard for less than new steel! You got to know where to shop, and how to weld of course.
Chief
chiefb711
Images: 62
Postby lrrowe » Thu Jan 29, 2015 8:47 am
jwhite wrote:I built mine out of 4x8 plywood with drop down legs made of shelving pine these photos show it down unfinished and folded up, I also have a drop down shelf,
When I am traveling I like my 6' width. But while I am building the inside, I like the 7' wide units so I could consider this approach. It looks nice.
Bob
lrrowe
Images: 439
Postby lrrowe » Thu Jan 29, 2015 8:52 am
Chief
I have limited material resources where I live and I do not know how to weld which I regret.
My bed platform will be 1/2" plywood reinforced with1/2" wood strips around the edges as Dirtclod did. While I did not run a weight comparison, I will bet this approach is not much heavier then either an aluminum or steel one. I suggest this because even with the metal frames, you still have to have some sort of platform for the mattress. That is added weight.
Bob
lrrowe
Images: 439
Postby AZ_Desert_Rat » Fri Jan 30, 2015 11:54 am
lrrowe wrote:Hey John, welcome back. I have not much since you and I last posted on this. Long story tried to made short is my back keep me down to doing just about nothing? I am on the rebound and starting to pick up energey and speed. I have not build my bunks yet, but when I do, they will be wood. I have the design in mind and I will look for another posters link which I will copy and I will post it here.
Found it.
Dirtclod's project.
Hi Bob,
Sorry to hear about your back, but am glad you are on the rebound :applause:
I haven't done much on my CT either, but because of my thin blood (It is still thick from So. Arizona) and I really just don't feel like working on the trailer in the driveway at 30 degree temps ... I'm also still trying to arrange the garage so I can find things :oops:
I used it to move some furniture for my wife and camped in a couple times, but since November, it has been collecting snow in the driveway :(
I, like you, have roughed in some ideas and will probably go with wood for the frame and bottom; however, I think I am going to go with homemade steel hinges. As my trailer is only about 68" wide inside (6' minus walls), I want to make the beds fold down closer to the walls and pull out a few inches from the walls when folded up, this will allow for the mattress and bedding ... The whole idea is to allow a bit more room between the bunks when both bunks are down :thinking:
I have a piece of garage door "L" brace about 5' long that should work for the bed-side hinge bracket ... the wall bracket will need to be a wall bracket that extends up from the floor and extends out a few inches to the pivot point ... anyway, something like that (I think I'll build a wood mock-up before I start cutting steel) :thinking:
Take care of that back, we need to get you on the road and camping this next spring :vroom: :vroom:
John (JC)
AZ_Desert_Rat
Images: 55
Postby lrrowe » Fri Jan 30, 2015 7:31 pm
I think I can visualize your hinge plan.
I was going to have my hinges about 8 inches away from the wall because I probably will use a 6 to 8 inch thich mattress. Guess I should get the mattress before I finalize on the distance.
This cold trend has me house bound most ot the time. I guess I need to man up and get out there. Afterall, I grew up in the Adirondachs and schooled in Michigan. But as you say, we have thin blood now.
Have you embraced the Big Ten yet?
Bob
lrrowe
Images: 439
Postby NO David! » Sat Jan 31, 2015 6:04 pm
Whatever you decide, I like the versatility of vertical e-track; because it's so... "versatile".
NO David!
Images: 37
Postby PigTrail » Sun Feb 15, 2015 8:05 pm
I used both wood and metal. Pics and description of the Murphy Bed here...
viewtopic.php?f=42&t=60222
Let me know if you have any questions. Good luck!!
Richard
@DualSportDispatch on IG
PigTrail
Postby AZ_Desert_Rat » Sun Feb 15, 2015 9:12 pm
Hi NO David!
I like the looks of the bunks in your camper :thumbsup:
Where did you get them or did you make the bunks in your trailer? They look like spring support for the mattress, is this correct?
Can you give me any info on these ... size, cost, etc.
Thanks much...
John (JC)
AZ_Desert_Rat
Images: 55
Postby sdiver68 » Sun Feb 15, 2015 9:25 pm
I'm surprised I don't see more premade bed frames with slats. They are so cheap, maybe even cheaper than materials and no welding required.
sdiver68
