Mobile Fit Club Build - Tommy2tone_1999
Re: Mobile Fit Club Build - Tommy2tone_1999
Postby Tommy2tone_1999 » Fri Dec 26, 2014 12:45 pm
Thanks so much!
More updates:
Putting more panelling on the cabin walls
Glueing the aluminum to the roof. Using 3M 4200 Marine Adhesive just around the edges to let the aluminum flex when the temperature outside changes. No the aluminum is not painted pink. That's just the protective coating to prevent scratches.
Building the frame for the galley hatch.
Last edited by Tommy2tone_1999 on Tue Mar 22, 2016 12:51 pm, edited 2 times in total.
Make time for fitness and it'll make time for you.
http://TommyDoran.com
http://tommydoran.com/favor
Interview: http://goo.gl/Non1oR
Build Journal - http://www.tnttt.com/viewtopic.php?f=50&t=58395
Come find me on Facebook - http://www.facebook.com/tommy.doran
Tommy2tone_1999
Postby dales133 » Fri Dec 26, 2014 5:02 pm
Nice looking trailer tommy
dales133
Postby Tommy2tone_1999 » Mon Jan 12, 2015 9:14 am
Overlapping sheets of aluminum on the roof.
Bending bead board panelling for the inside of the hatch.
Bending and applying the aluminum trim for the inside of the galley hatch.
Moisture proofing the inside sufaces on the hatch.
Putting the outside plywood on the galley hatch.
Diamond plate trim along the bottom
Screw holes on the outside of the hatch sealed
Diamond plate rock guard in place.
I have a small dilemma. There is no spar behind the top edge of the rock guard, (ie nothing to screw into). What is the best way to attach a trim molding to the upper edge?
Last edited by Tommy2tone_1999 on Tue Mar 22, 2016 12:58 pm, edited 3 times in total.
Tommy2tone_1999
Postby 225 » Sun Jan 18, 2015 3:15 pm
What colors did Denver sign supply keep in stock? Making a run there next week probably.
Looking good BTW. :thumbsup:
Postby dales133 » Sun Jan 18, 2015 4:01 pm
If you've got nothing to screw into polyurethane adhesive?
dales133
Postby Tommy2tone_1999 » Mon Jan 26, 2015 9:11 am
Glueing the aluminum skin to the hatch.
I had some spring back in the hatch after putting on the aluminum skin. Nothing a few screws won't fix. They'll be covered up by the edge trim later.
Checking the fit on the hatch.
OOPS!! I cut the top of the galley hatch hinge too short, it doesn't overlap the edge molding on the galley wall. Good thing I saved the scrap piece. I cut the hing in half (on the hatch side) and put the scrap in the center. It will be sealed to the hatch with marine adhesive so it shouldn't leak.
In case the split hurricane hinge leaks, I came up with a mini gutter with a diversion hose to catch any drips and carry them outside the galley.
The hatch is in place but there is some spring back. Looks like I'll need a little extra weather stripping and some draw tight latches.
Last edited by Tommy2tone_1999 on Tue Mar 22, 2016 1:02 pm, edited 5 times in total.
Tommy2tone_1999
Postby Tommy2tone_1999 » Mon Jan 26, 2015 9:13 am
Denver Sign Supply only has mill finish and white sheets.
Tommy2tone_1999
Postby lfrazer98 » Wed Jan 28, 2015 12:42 am
Enjoyed reading through your build! Your pictures made it look a lot easier than it was for me and my father. Everything seemed to come together so well. Looking great!!
lfrazer98
Images: 217
Postby Tommy2tone_1999 » Fri Jan 30, 2015 2:45 pm
It just looks easy because i left out a LOT of BooBoo pics LOL.
Tommy2tone_1999
Postby Tommy2tone_1999 » Fri Jan 30, 2015 2:47 pm
Hatch supports in place.
Last edited by Tommy2tone_1999 on Tue Mar 22, 2016 1:04 pm, edited 1 time in total.
Tommy2tone_1999
Postby Tommy2tone_1999 » Fri Jan 30, 2015 7:45 pm
Gutters over the doors installed.
Last edited by Tommy2tone_1999 on Tue Mar 22, 2016 1:05 pm, edited 2 times in total.
Tommy2tone_1999
Postby S. Heisley » Fri Jan 30, 2015 8:44 pm
It looks like you're nearing the home stretch! :applause:
Postby Tommy2tone_1999 » Tue Feb 03, 2015 9:53 am
Installing the vent.
Aluminum trim going on.
(Nothing to screw into behind the skin, so I simply glued it on with 3M adhesive (4200) and 2 screws on the ends holding the caps down will keep it in place.)
Pam loves to peel skin when I get a sunburn so she is in her glory doing this.
Last edited by Tommy2tone_1999 on Tue Mar 22, 2016 1:08 pm, edited 1 time in total.
Tommy2tone_1999
Postby KCStudly » Tue Feb 03, 2015 11:32 am
TMI :?
Postby TxDave » Tue Feb 03, 2015 12:24 pm
Good looking trailer, Tommy. I'm like Pam...I enjoy removing the plastic film from the aluminum. Its kinda like unwrapping a present. I really like the profile you've chosen. I think my next build will use that shape.
Dave and Jan Clay
Temple, TX
TxDave
Images: 65
