Pmullen,
Thank you for the bare ply comfort input. The nose IS flat across the front, and has a triangular tongue box in front of that. As I look at the hinge length of 36", it may be a little short. I'll review and maybe stretch it a little longer. Thank you.
KennethW,
I wondered about lowering the floor, but to be able to get the trailer into my garage AND have standing headroom, I needed the clam design. Thank you.
M C,
I am struggling with opening windows due to space limitation, and was settling on non-opening portlights in the front and sides. The rear wall will allow some openings. And then...POW! You are awesome!
I had not considered windows in the bottom shell - DOH! Thank you! I have room for two nice ones in the lower side wall - and protected when travelling! Thanks!!
This will be a complicated build, in that the designed in curvature for a bottoming and topping interlocking rail on the lower shell that need to mate with a double-edged middle rail attached to the top shell. sort of a vertically oriented []> >[]> >[] series of bent board laminates (top shell gets middle rail) that seals it in the up or down orientations. All of the plywood curves are not difficult; easier than a plywood boat.
Another challenge is the hinged rear door. The lower rear wall is fixed to the lower shell, with a door-way cut through. The top wall is fixed to the upper shell, and seals everything in the clam-down position. The door is mounted in a doorway of the top wall, with the bottom half of the door piano hinged to swing out and up before lowering the clam. The clam hinge location allows the back walls to swing clear and back into place - to seal up or down. but the door will be tricky to get right. Nothing impossible, but the details need working out. The tail lights are in the awing/tailsection.
I'll be in the drawing phase another month or three, then will scale model the critter. Building phase this winter is for an 18' ply rowboat, so plan to start ttt construction next winter.
Butch
