Ned's Grumman 2 (ish) TD in New Zealand
Re: Ned's Grumman 2 (ish) TD in New Zealand
Postby dales133 » Fri Jan 30, 2015 8:31 pm
Lol.
dales133
Postby Ned » Sat Jan 31, 2015 12:46 am
here is a pic o the white oak shadow RV ply i got;
and today i did some more trailer work. This is upside down, but i welded in the plated to bolt the floor to (9 of them)
and the rest of the bracing
now doing the last drawing of the mid wall, so i can cut those out tomorrow so we can start going vertical!
Build Journal :: My Grumman 2 (ish) TD
Ned
Postby Ned » Sat Jan 31, 2015 12:49 am
and i asked my little brother if he could come help me move a couple sheets of ply from Remuera to Onehunga, and this is the result
seems a little inefficient if you ask me haha
Ned
Postby dales133 » Sat Jan 31, 2015 12:57 am
Nice progress
dales133
Postby Ned » Sat Jan 31, 2015 1:32 am
me and my buddy stood on the middle beam, together putting 300kg, aka 660 lb (or just shy of) on it and we gave it a little bounce and was solid, so pretty happy :) should be nice and solid! and kinda heavy maybe
Ned
Postby Ned » Sat Jan 31, 2015 2:19 am
Taking out too much? i always hear that people wish they took out more etc, so thought this was pretty good...
Ned
Postby Sheddie » Sat Jan 31, 2015 4:35 am
That side wall looks good. :thumbsup: It looks like you have all the mounting points for cabinets etc covered. Main thing is that anything you want to screw to the walls have something solid behind them. :thinking: We have found that if we are likely to get any condensation on the inner walls it is where we haven't cut the ply out.
Sheddie
Images: 1129
Postby dales133 » Sat Jan 31, 2015 5:13 am
I like
dales133
Postby Sheddie » Sat Jan 31, 2015 5:53 am
I take it from the line between the recesses for the roof beams that they will be sitting on top of the 4' sheet, with packers between. We did the with ours, it gave as a little bit more head room inside. The only thing is that you need to allow for the extra height on the exterior cladding. We used 1.5 m wide ACL and used the off cuts for drawer fronts.
Sheddie
Images: 1129
Postby Ned » Sun Feb 01, 2015 4:40 pm
that is exactly right, but wont really have any extra head room. It's still is 1200 high overall and 2700 long
piece of wood on the machine
chop chop chop
ready to drive back home :)
and mocked up
Ned
Postby Sheddie » Mon Feb 02, 2015 3:35 am
Good progress Ned. It's handy to have access to a machine like that. :thumbsup:
Sheddie
Images: 1129
Postby dales133 » Mon Feb 02, 2015 4:24 am
Yea! Made my sidewall cuts look dark age..use all your favors and convenience where you can.
NJ bud
dales133
Postby felixx » Mon Feb 02, 2015 4:38 am
aweswome work
:D
felixx
Images: 22
Postby Ned » Mon Feb 02, 2015 8:45 pm
Thanks guys :) i obviously didnt do much of it haha but it does look good, and i'm very happy with it!
To cheat a bit more, i managed to get someone to cut up some more plywood with his table saw for all of the galley bits and bobs, so i can get started on that soon!
Ned
Postby Ned » Tue Feb 03, 2015 2:51 pm
looks like i have an evening or two worth of assembly to do here...
all the wood for the galley cut :)
Main bulk heads out of 17mm, and the rest out of 12
Ned
Users browsing this forum: Google [Bot] and 4 guests
