daveesl77 wrote:Well, me being me, I began to consider other options. I really like the more teardroppy shape. I also want the ability to sit up inside. The galley is an absolute, but it must also be easily accessed and dear wifey refuses to have it internal during use. So still looking at the 5x9 footprint, but actually going back to the 4' height and not 4.5 or 5.
So I started thinking, why does the galley have to be in the back? The back part of a trailer gets most of the shakes and jars.
Why does there have to be a giant "hatch"? Only if you have the galley accessed from the back.
daveesl77 wrote:To begin with, I have an 8' trailer frame with steel cross members every 2 feet. This essentially creates 2'x4' "compartments" on the floor area when I build it up. Comp 1 is where the galley would be, Comp 2 would be the section in front of the axle. Comps 3 & 4 are in the back of the camper.
If I put the galley in the front of the camper and made it where the entire unit actually slides out of the side and not out of the back? Upper and lower cabinets both in 2 separate components but they link up when extended.
In transport it locks into place inside. For camping it slides outside, one end locking into the inside of the camper, the other supported outside. It uses leveling rods to support from the ground. It has both interior and exterior "hatch covers", to seal the opening when traveling and to seal it when extended.
daveesl77 wrote:The bed is queen sized, but actually runs from back to front (6' total length). The rear 4' of the bed support is permanently mounted. In "Comp 2", the compartment immediately behind the galley compartment I build a drop floor with removable top. The drop floor works to make this a sit up camper, as it drops the floor about 8" below the normal level, allowing a settee to be created that is very low to the normal floor, but at a standard floor to butt height. This gives situp headroom. With the galley pulled out, the top then can become the seat part of a settee, with the foot part being down in the drop area. The "back" of the settee would be permanently mounted behind where the galley stores. This works because the front of the camper will have the extending forward curve. The settee then faces to the rear. For the final 2 feet of the bed I can either use the drop floor top as the final bed section or make another slide out section to extend the bed to full length.
daveesl77 wrote:The entry door would be on the same side as the galley, at Comp 2. That way, if we were doing a quick overnight and did not want to extend the galley, we would enter straight into the bed. One of my pop-up 12' canopies covers the entire trailer and galley area.
daveesl77 wrote:This lets me go with a more swooping teardrop design, reduce the overall height, not have to build a hatch and make the galley very accessible. It gives my dog at least 2' x 5' of floor space. We have a sitting area if needed, permanent storage around the rear area, and probably a lighter unit since I don't have to build the hatch structure.
So what am I missing here? It seems to simple of a concept, but I cannot see any drawbacks yet.
I'll try to draw up a mockup, but my drawing talent leaves a lot to be desired.
dave
