walkrdg wrote:Nice looking trailer. I wound up buying a Haulmark, but Pace was the other one I had at the top of my list.
My trailer isn't under construction yet, but my plans are similar to yours, with the exception that I don't plan to lift the floor. I'm just going to fasten some 1" or 2" foam, glued and screwed. my floor is 3/4" plywood.
As far as sound-deadening goes, your spray will probably be fine, but I doubt it would be necessary. I once paneled the inside of a cargo van with pink insulation in between, after first painting undercoating to the metal walls for the insulation to stick to. ( Maybe, though, the undercoating would be similar to your spray). The stock van was horribly noisy when I got it, but after the insulation, it was as quiet as a Cadillac.
Dave
Doublacola wrote:Looks like you have a good plan. Good luck with the build.
svu3r93 wrote:A quick question....is your flooring really only 3/8", or is that a typo? Good luck with your build - and can you send some of your wet weather down to northern Nevada?!
