Its sort of mine!
Its sort of mine!
Postby Padilen » Thu Feb 05, 2015 4:09 pm
American Hauler
7x12x7-V-nose All Aluminum.
About 1550LBS. single axle with brakes.
It will be a slow build, I have very limited income. It will be a cycle, kayak, camper, yet still be usable for cargo hauling. It was purchased for my use, its not quite what I wanted but its what I can use. I want/need shower, toilet bed that raises to ceiling. I have torn down around 25 trailers and not much was reuses able. I'm getting a pick-up camper to dispose of and hope to be able to use some of it. I've started the insulation walls and ceiling are already done, under floor is next. I'm waiting for my friend to drop more off.
I cant seem to post pictures, from my lap top, but I have this on cell.
Padilen
Re: Its sort of mine!
Postby Woodbutcher » Thu Feb 05, 2015 4:50 pm
Good looking trailer. You should be able to make that work out fine.
Woodbutcher
Postby Padilen » Thu Feb 05, 2015 4:57 pm
Woodbutcher wrote:Good looking trailer. You should be able to make that work out fine.
Thank-you
had thought Id get a lot done but its been slow!
Padilen
Postby lrrowe » Thu Feb 05, 2015 5:43 pm
Padilen, well you did fine getting this picture up. Nice trailer. I like the two tone and considered that myself, but needed to keep the cost down.
Read as many of the older posts in the forum. In all the categories, there is a ton of info. It is great to use the ideas of others and then share your own.
Bob
lrrowe
Images: 439
Its sort of mine!
Postby Padilen » Thu Feb 05, 2015 6:13 pm
The you tube that someone else posted is just about what I planned on. I had thought about Happyjac until I saw the prices. Deleted video, of other trailer.
E track or unistrut will have to do. My mom thought a Winnebago style bed, but I see where they're getting them from scrap yards.
The trailer is my moms, she bought it for my use. But any additions are my expense. I need spare tire and brake controller before I can spend money on interior.
I'm hoping pick-up camper bathroom and tanks are good. I will also get a portable tank. I believe the pickup camper black water tank sits under shower/toilet combo. So portable will be grey if needed and "overflow".
Adding the you tube link, as an attempt to remove the pic of someone else's build.
https://youtu.be/vGpnWdflPVg
Padilen
Postby Padilen » Tue Feb 10, 2015 8:54 pm
I got the rest of my insulation yesterday.
Today I managed to get the plywood off the ramp door. By carefully drilling and chiseling wood away. The bolt holding the cable was hindering limiting wood. I hope to get started on cutting the instillation tomorrow.
Warning to those that don't know. The springs on the ramp door are set to lift the weight of door with the wood on it so be careful. I managed by myself but would recommend 2 people.
This is what I've done as I get money for TAZ.
Padilen
Its sort of mine!
Postby Padilen » Wed Feb 11, 2015 9:11 pm
Worked on insulation of the ramp. 2 sections left where the latches go. I don't like the factories system of supporting them.
I didn't insulate a small section of side panels. I didn't want to remove door opening trim. But it's been bothering me. So I used a hair dryer and heated up the glue. It did bend but I got them off. I'm going to do something with the wiring before I insulate.
1 piece of foam for my seat cushion/ extra bed came today.
Padilen
Its sort of mine!
Postby Padilen » Thu Feb 12, 2015 2:10 pm
Flipped over ramp plywood and coated back side with a waterproofing.
This is how I eased plywood removal on ramp-without removing cables.
Found this under trailer- bare wire.
Padilen
Postby Padilen » Sat Feb 14, 2015 1:24 pm
Second piece foam for cushion came today.
Padilen
Postby Padilen » Tue Feb 17, 2015 3:50 pm
I have everything now to make my cushions... But thread ! Maybe I'll just duct tape it
Padilen
Its sort of mine!
Postby Padilen » Tue Feb 24, 2015 10:35 pm
So I've been working on my sewing machine. Guess I needed more than thread. Because my fabric pieces are large Im having a hard time keeping them straight. After making nice progress my sewing machine stopped sewing correctly. So I pinned the one side of zipper. I need to figure out ends but that's for another day.
The money I've been trying to save for a spare tire went for a mattress. My neighbor that's going to help with my bed design will need it for measurements.
Padilen
Postby Padilen » Mon Mar 02, 2015 11:22 am
Cushions are sewn ! Another neighbor to the rescue with a loaner sewing machine.
The neighbor(season/part time) that's going to design my lift bed took measurements and will get me a build list and print but I'm hoping he'll do more- his close friend is a welder of specialty metals. Id like it in aluminum so maybe ....
Padilen
Its sort of mine!
Postby Padilen » Wed Mar 11, 2015 6:22 pm
I got a used single sink. I removed a toilet shower combo from a pick-up camper and the furnace and hot water heater. I couldn't fit toilet shower in my Jeep so I'll have to pick it up later.
Padilen
Postby Padilen » Fri Mar 13, 2015 7:04 pm
Ordered a water tank, the one from pick-up camper was broke where fittings connect. The one from TAZ had holes.. Also ordered a faucet for sink.
I'm rethinking using any of my scrapped parts. Not worth having a failure in my CT.
I'm disappointed, a lot of work for nothing!
Padilen
Postby hankaye » Fri Mar 13, 2015 8:21 pm
Padilen, Howdy;
Perhaps a momentary disappointment ... yet may prove to be an invaluable
experience for the future.
hank
hankaye
