Do automatic resetting 12v circuit breakers work in just one direction? If they do, would it be safe to say you can't use a resetting circuit breaker in-between your battery and a charger/controller.
Or inline from your tow vehicle to the battery? Do you revers the way it should be hooked up? Batt/Aux or Aux/Batt
Battery's power runs to the controller for 12v power and power is run back to the battery during charging, if the breaker is one directional then some part of the system won't be protected??
Am I just over thinking this
Wayne
http://www.cnhhdq.com/products/ST-1013A169.html
