Da'engineer wrote:I was estimating based off of my wife's length of shower standard gpms which is 2.0 times ten is 20 gallons enough for 2 days atleast is 40 then a misc amount for handwashing unless I am wrong.
lrrowe wrote:That is what I am planning on doing. Only a 10 gal. tank in the CT and more water in the truck bed (either 5 gal containers or larger ones). I could use a 12V pump to transfer the water from the truck bed to the trailer when needed. Also we will use the Navy shower technique as any water we use has to be captured and disposed of which in many cases might be inconvenient at times.
