darrellbeck wrote:Thanks lrrowe, for correcting my error. To help make up for it, here is some information on what I installing, and that I am happy with.
If you go to Frank Bear at teardroptrailerparts.com and check out his #LT25 lights you will find out that they are incandescents @ $7.95 for 6 of them, or $4.95 for 3.
Then go to EBAY and search yitamotor 10 48smd this will take you to a site where you can buy 10 led conversions for these for about $16.00
Put them together and you end up with 9 lights and a spare led for about $33.00 or about $3.33 each. They are quite bright and look very good.
darrelbeck,
I did the lookup and I think this will work for me. Each lamp will only be 192 lumens, but if I order the 6 lamps from Frank Bear, that combo would produce almost 1200 lumens which might work for me to start with. Cost will be about $3.00 each (sub of two parts) or $18 for 6. I like the dual switch capability with one switch on the lamp and the use of an inline switch to all at once.
But first, since it sounds like what you have used them. If so, what color level did you pick? I like the warmer 4000k over all but I feel the cool white (6000k) looks like it may give a little more light (can find a lumen spec to compare both of them).
