Slideouts
Slideouts
Postby RVServiceGuy » Thu Feb 12, 2015 8:52 pm
As an RV repair tech I figured out real quick that slideouts are the Achilles heal of your average tt. Has anybody had any luck perfecting them? Or are they pretty much garbage? All I have to go off of is what major tt manufacturers send my way.
RVServiceGuy
Re: Slideouts
Postby Martiangod » Mon Feb 16, 2015 11:29 am
Pretty much garbage!!!
Slide out are akin to planned obsolescence.
All the RV manufacturers have perfected slide outs,
Get it out of their plant and to the dealer, let the techs deal with it.
That's perfection to the manufacturer.
And in two or three years when the trailer is garbage, sell them another one. None of this trailers lasting for 20 years chit. That's not good for business
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Re: Slideouts
Postby jstrubberg » Mon Feb 16, 2015 2:18 pm
Aside from the problems sealing them, slide outs add complication and a LOT of weight to a trailer. Since teardrops aim to avoid both of those issues, they are not popular.
The more stuff I take along, the more time I spend taking care of my stuff!
jstrubberg
Re: Slideouts
Postby Midget » Mon Feb 16, 2015 3:27 pm
We have fun at trailer parks telling people we just brought the slide out this trip and left the coach at home. Some get it and some don't.
Midget
Images: 91
Re: Slideouts
Postby fullon627 » Sat Feb 21, 2015 10:44 pm
jstrubberg wrote:Aside from the problems sealing them, slide outs add complication and a LOT of weight to a trailer. Since teardrops aim to avoid both of those issues, they are not popular.
My daughter and I are building a small trailer with a rear slide out kitchen. It will free up a lot of space inside while camping. I think it will add an extra 200-250lbs to the trailer. But we didn't start out to build a light weight one in the first place. Her car has a towing rating of 2000lbs. I think this trailer is going to weigh around 1500lbs fully loaded ready to camp. I really don't foresee any sealing problems because of its location and configuration. Your welcome to follow along to see how it comes out.
It's a great world if you don't weaken!
Boats float and airplanes fly!
If you boat sinks you can swim!
If you airplane falls you can't fly!
Ken from Eureka Ca.
Boo's Build viewtopic.php?f=50&t=60867
fullon627
Images: 283
Re: Slideouts
Postby Vedette » Sun Feb 22, 2015 4:21 pm
Boy those sliders had better be pretty stout! As, by the looks of it you have already used what looks like 2x4;s and 3/4" plywood?? :shock: And you have not started to build the kitchen yet?? :roll:
We will follow along, but at some point I think you will find that weight will become a major concern!
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Re: Slideouts
Postby fullon627 » Sun Feb 22, 2015 9:58 pm
Vedette wrote:Boy those sliders had better be pretty stout! As, by the looks of it you have already used what looks like 2x4;s and 3/4" plywood?? :shock: And you have not started to build the kitchen yet?? :roll:
Good Roads
Brian & Sandi
Brian, those were oak real 2x4s that I cut down to 3x1 1/2. Yes that is 3/4 ply on the floor. It needed to be because my water tank, cooler, etc will be mounted to that floor. The walls and rear hatch wont be that thick. The slides are 500lb commercial slides made in USA for fire trucks and such. I don't think loaded ready to camp the slide out will weigh that much, but you may be right. With the slide out, there is still 10 inches of it inside the trailer. The water tank and some other heavy things will still be inside the trailer not loading the slides much. I'm also going to put a caster on the slide in the middle to roll on the floor of the trailer. The slide out will have stabilizing leveling jacks under it when it's out
Ken from Eureka Ca.
fullon627
Images: 283
Re: Slideouts
Postby Vedette » Mon Feb 23, 2015 12:49 am
Good to hear you have used the best stuff you could to solve the potential weight problem! :thumbsup:
The center caster is a great idea! :thinking: As even 3/4" plywood has a tendency to sage.
What kind of jacks do you have in mind.
God Roads
Brian & Sandi
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: Slideouts
Postby fullon627 » Tue Feb 24, 2015 10:06 pm
Vedette wrote:Good to hear you have used the best stuff you could to solve the potential weight problem! :thumbsup:
God Roads
Brian & Sandi
Brian, I've narrowed it down to one of these two:
Aluminum folding telescoping legs @ $28 each. They have a weight rating of 200lbs each. These would be mounted under the slide.
Or these 12 volt linear actuators @ $65 each (kinda spendy for a budget build). They have a weight rating of 330lbs each. I would mount these in the rear inside corners of the slide with separate switches for uneven ground.
Ken from Eureka Ca.
fullon627
Images: 283
Re: Slideouts
Postby fullon627 » Wed Feb 25, 2015 10:27 pm
BTW, I don't think I'd own another full size trailer or fifth wheel with a factory built slide outs. Been there done that.
Ken from Eureka Ca.
fullon627
Images: 283
Re: Slideouts
Postby RVServiceGuy » Wed Mar 11, 2015 8:47 pm
They are total garbage. I hate working on them with a passion. My problem is my wife and I often camp with friends. I need something big enogh for two couples and a slide seems to be the best way to go. I really couldn't pull a cargo trailer with our Ford Edge and it will be a minute before I can get a truck. I refuse to buy a camper. I could build two campers but most of our friends couldn't tow it.
RVServiceGuy
Re: Slideouts
Postby Greg M » Thu Mar 12, 2015 12:03 am
Build a second one without a galley. I can tow my 4x4x8 one (with no galley) with a 1.6litre Honda
Greg M
*Geek Extraordinaire
Images: 85
Re: Slideouts
Postby Ron Dickey » Thu Mar 12, 2015 12:22 am
you could just do a swing down.
129389
173882......173887
Ron Dickey
Images: 787
Users browsing this forum: TimC and 1 guest
