Ned's Grumman 2 (ish) TD in New Zealand
Re: Ned's Grumman 2 (ish) TD in New Zealand
Postby Ned » Wed Feb 18, 2015 12:48 pm
thanks :) but i have to be, in 14 days from now, it has to be on the road and is going to be towed to the Coromandel for a few days... so probably even a touch behind really.
Build Journal :: My Grumman 2 (ish) TD
Ned
Postby Sheddie » Wed Feb 18, 2015 1:52 pm
:shock: :? No sleep between now and then :goodnight:
We were there Waitangi weekend and will be back again ANZAC weekend.
Sheddie
Images: 1129
Postby Ned » Thu Feb 19, 2015 1:07 pm
Made the inside cabinets last night :)
so there are some little cubby holes down the bottom/sides for my phone etc, a car radio with DVD player, and one of them 12V/USB things for power :)
need to trim the doors a touch as they dont close as they are too long, but i can do that some other time
Ned
Postby Sheddie » Thu Feb 19, 2015 1:35 pm
Ned wrote:need to trim the doors a touch as they dont close as they are too long, but i can do that some other time
Going well Ned, :thumbsup: but, get as much of the interior stuff finished before you put the roof on. :thinking: It can be rather awkward once it is closed in (and not being rude), for a big guy like you.
Sheddie
Images: 1129
Postby Ned » Thu Feb 19, 2015 1:47 pm
thats exactly what i'm doing :) though it's about done now! so roof soon!
Ned
Postby Ned » Sat Feb 21, 2015 6:59 pm
Ceiling is on!
Ned
Postby Sheddie » Sat Feb 21, 2015 7:40 pm
:thumbsup: :pictures:
Sheddie
Images: 1129
Postby Ned » Sun Feb 22, 2015 1:54 pm
forgot to take recent photo's but here ist he ceiling test fitted on Saturday
getting dark inside!
put a door on while i waited for some glue to dry for the ceiling
and first section of the ceiling fitted!
and i mounted some inside lights :D
the whole ceiling is mounted, some of the insulating foam has gone in as well, and hung the doors properly with recessed T-nuts and some M5 dome bolts.
PROGRESS IS BEING MADE AND IT'S COOL!
Ned
Postby KCStudly » Sun Feb 22, 2015 3:52 pm
Looking really nice there!!! :thumbsup:
Postby dales133 » Sun Feb 22, 2015 4:02 pm
Good stuff ned looking good.mines on the back burner due to work again
dales133
Postby Ned » Sun Feb 22, 2015 4:04 pm
Cheers guys :) I'm very happy with it so far! now just need to push to finish it...
Ned
Postby Ned » Sun Feb 22, 2015 4:49 pm
i knew i shouldnt have added the numbers in the second post... i'm up to $5000... oops! Didnt think that when i started... and have quite a bit more to spend as well :(
Ned
Postby Sheddie » Sun Feb 22, 2015 7:26 pm
Hi Ned :thumbsup: :thumbsup: :applause:
You are going to be camping in no time!
Point to note, if you are going to be running wires through the Polly insulation, it pays to conduit it. If you doing any 230v check with the power board caravan inspector, as I think it is required for that. The Polly can react if in contact with the wire insulation.
As for the costs, you should take your first figure, add quite a bit more, then double it. And you will still be short :cry:
Sheddie
Images: 1129
Postby Ned » Sun Feb 22, 2015 8:02 pm
Cheers for that. No mains in my camper, just some lights, a car radio/dvd player and a 12V TV. Will carry a battery charger for when i am near mains to top it off, but am hoping to run solar panels in the near future so no need for mains at all really, but i will check whats up with the insulation and polystyrene! did not know that!
Ned
Ned
Postby Ned » Sun Feb 22, 2015 8:12 pm
Had a quick read, and looks like putting down some polyester tape or something will do the job. Will likely not be an issue, but better safe than sorry right? cheers for the heads up!
Ned
Users browsing this forum: jdeleon and 4 guests
