AC and DC switch contacts are manufactured with different materials in order to withstand the arcing that occurs, and the resulting degradation of the switch contacts. AC circuits typically break cooler than DC circuits because the current drops to zero 120 times per second, which means arcing stops at least by the time the current goes to zero. Current in a DC circuit does not drop to zero immediately when the contacts open when there is an inductive component in the circuit. In a DC circuit, the voltage will spike when the contacts open and the arcing will be significantly more than in the comparable AC circuit. This results in more rapid contact degradation through pitting from the high temperature arc. The voltage rating only talks about insulation factor. Current rating only talks about current capacity, neither of which is related to the other. So an AC switch is NOT equal to a DC switch.
This is really no big deal I installed the shallow blue electrical boxes and purchased the solid covers. I drilled the correct size hole for a dc rated switches and that was that. As the contacts are "harder" the dc switches CAN be used for ac applications. I liked the fact I was able to easily get two switches in the box ( I think 4 maybe 5 would be possible).
I added DC bulb sockets to all the selected AC fixtures and made each light dual useage......
I selected a rotary and a flip toggle when I installed Chubby's dual element lights. The rotary was DC and the toggle was AC. In the dark I could tell by feel which I was about to use.
