plumbing question
plumbing question
Postby max6220 » Sun Mar 01, 2015 10:09 am
getting ready to install all my waste plumbing, My question is the pipe going into the grey tank do you just cut a hole with a hole saw then caulk it in, use a grommet type fitting, glue a fitting to the tank ?? thanks
max6220
Re: plumbing question
Postby MtnDon » Sun Mar 01, 2015 11:23 am
The grommet type fittings like Uniseal are great. IMO, better than trying to caulk as they do allow for some wiggle as you bounce down the road and are removable if that is ever necessary
MtnDon
Images: 24
Postby hankaye » Sun Mar 01, 2015 12:00 pm
max6220, Howdy;
Fully agree with MtnDon on the grommet seals. It's what is used for the full-sized RVs.
hank
hankaye
