Stepping into the TearDrop void
Postby trailtroll » Fri Feb 20, 2015 3:34 pm
I have done it.
I am on my way with the trailer frame started.
Off to see sheddie's TD today, and get some inspiration.
I woke up this morning and all of my stuff had been replaced with exact replica's
trailtroll
Re: Stepping into the TearDrop void
Postby Sheddie » Fri Feb 20, 2015 6:30 pm
Well done Wayne :thumbsup: It is good to see that you have made a start on both the teardrop and the build journal.
Welcome to the TNTTT site, I hope you get some useful ideas from it.
Sheddie
Images: 1129
Postby trailtroll » Fri Feb 20, 2015 11:38 pm
Thanks Frank, it was well worth visiting you and Dale, and seeing your TD.
Now its to work.
trailtroll
Postby Sheddie » Sat Feb 21, 2015 12:05 am
Hi Wayne, it was good meeting you and I hope you got some ideas to work with. Keep us posted on progress and we will come and check it out.
Sheddie
Images: 1129
Postby trailtroll » Mon Feb 23, 2015 1:09 am
I have had to widen the axle, from 1.2m's to 1.5m's, so we can accomodate a double inner sprung mattress.
trailtroll
Postby Sheddie » Mon Feb 23, 2015 1:43 am
That will be a good move :thinking:
And we need to get you loading smaller photos :pictures:
Sheddie
Images: 1129
Postby trailtroll » Sun Mar 08, 2015 3:26 am
Trailer frame ready for the decking @ registration.
trailtroll
Postby felixx » Sun Mar 08, 2015 3:35 am
Kia Ora Bro!
Good work!
Welcome
felixx
Images: 22
Postby Sheddie » Sun Mar 08, 2015 4:47 am
Hi Wayne,
Frame looks good :thumbsup: keep it up.
And the photo is a better size too :thumbsup:
Sheddie
Images: 1129
Postby trailtroll » Mon Mar 23, 2015 3:21 pm
Trailer, with removable side's, is finished and tows really well.
Am starting the teardrop now, which will sit on the flat deck, and be removable, when the trailer is needed.
trailtroll
Postby felixx » Mon Mar 23, 2015 3:23 pm
AWESOME
felixx
Images: 22
Postby Sheddie » Mon Mar 23, 2015 6:23 pm
Sheddie
Images: 1129
Postby Sheddie » Mon Mar 23, 2015 6:27 pm
Hi Wayne, you will have to re-load those first two photos at a smaller size. It makes everything rather small otherwise.
Sheddie
Images: 1129
Postby trailtroll » Sat Apr 04, 2015 10:16 pm
I have been flat stick on the teardrop, awaiting doors from Little Guy, USA, $1120.00 delivered. Should arrive this week?
One of the walls
In side floor
This is the under floor
under floor.JPG (171.01 KiB) Viewed 3090 times
trailtroll
Postby trailtroll » Sat Apr 04, 2015 10:21 pm
More of the great teardrop build.
Our cut-outs on the walls
wall cut-outs.JPG (191.85 KiB) Viewed 3090 times
Start to the galley
galley start.JPG (124.44 KiB) Viewed 3090 times
Two walls on and galley in
two walls on.JPG (157.34 KiB) Viewed 3090 times
trailtroll
