Little Red Benroy
Little Red Benroy
Postby TxDave » Tue Mar 17, 2015 9:55 pm
Well, I built another one. This one took 37 days from start to finish. I fabricated the frame from 2x2 square tubing. I decided to go with 14" wheels instead of the 12" I used on my previous builds.
I used my router to cut the Dado joints for the bulkheads and cabinets. First time to try this and it went well. The walls are 3/4" oak plywood.
I fabricated the hatch frame from 3/4" square steel tubing. This made for a light weight yet rigid hatch.
Dave and Jan Clay
Temple, TX
TxDave
Images: 65
Re: Little Red Benroy
Postby TxDave » Tue Mar 17, 2015 9:59 pm
I used this spring galley hatch prop from Vintage Technologies. Works well and is easy to install.
We went for a simple galley layout on this build. Still has lots of room to store stuff.
I used these draw tight latches from McMaster Carr for a tight seal on the galley hatch.
Dave and Jan Clay
Temple, TX
TxDave
Images: 65
Postby TxDave » Tue Mar 17, 2015 10:03 pm
Here's a shot of the simple interior cabinet layout and electrical setup.
And...here's the finished product out for its first test tow. The pre-painted red aluminum really attracts attention.
Dave and Jan Clay
Temple, TX
TxDave
Images: 65
Postby Vedette » Wed Mar 18, 2015 12:14 am
Wow! Dave you have turned into a Teardrop building machine??? ;)
Way to go!
Anyone looking for a teardrop in Texas should contact you! :thinking:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby TxDave » Wed Mar 18, 2015 5:51 pm
Thanks, Brian. I am really enjoying building these things. Working on a project in the garage is my therapy.
Dave and Jan Clay
Temple, TX
TxDave
Images: 65
Postby pchast » Wed Mar 18, 2015 10:16 pm
Dave,
What did you end up with for weight on this design?
Thanks
pchast
Images: 97
Postby KCStudly » Wed Mar 18, 2015 10:44 pm
Looks nice and tidy. What is the tube sleeve mounted to the side wall outside of the galley prop? Kind of looks like a flag staff holder. I'm guessing some sort of canopy leg support. :thinking:
Postby TxDave » Thu Mar 19, 2015 12:25 am
Pete...it weighs 902 pounds.
KCStudly...that's a mount for my self-designed high-def TV antenna.
Dave and Jan Clay
Temple, TX
TxDave
Images: 65
Postby Vedette » Thu Mar 19, 2015 1:36 am
Time to make some travel plans to the North if you have not yet been here??
We would love to meet you guys and camp at a Gathering, Crawl or just around a campfire in the back forty?? :thumbsup:
Good Roads
Brian & Sandi
Vedette
Images: 443
