LED Question
Anything electric, AC or DC
LED Question
Postby Chris C » Sat May 27, 2006 10:24 pm
Does one have to put anything between the battery and an LED other than wiring? I don't know much about electric................but I know even less about LED's! :lol:
Chris :D
Chris C
Re: LED Question
Postby Dean in Eureka, CA » Sat May 27, 2006 10:28 pm
Chris C wrote:Does one have to put anything between the battery and an LED other than wiring? I don't know much about electric................but I know even less about LED's! :lol:
A switch would be nice, so you could turn it off and on. :lol:
Dean in Eureka, CA
The Fogcrawler
Images: 69
Re: LED Question
Postby Steve_Cox » Sat May 27, 2006 10:33 pm
:rofl: :thumbs up1:
Steve_Cox
Images: 196
Postby Sonetpro » Sat May 27, 2006 10:44 pm
All Led's need a resister in line. If your buying them to make your own fixture be sure they come with them already soldered on. I bought some off ebay because the price was good. When I recieved them the resister's was with them but not soldered on.
A led fixture will already have them built in.
Sonetpro
Images: 107
Postby SteveH » Sat May 27, 2006 10:46 pm
Chris,
Technically speaking, there must be a resistor between the battery and LED lights when they are powered by 12 volts because all LEDs work on approximately 1.5 volts. Having said that, if you buy a 12 volt LED fixture, the resistor is already built in, or there are enough LEDs to be wired in series to handle the voltage.
SteveH
SteveH
Images: 42
Postby SteveH » Sat May 27, 2006 10:47 pm
Steve,
You type faster than I. :lol:
SteveH
SteveH
Images: 42
Postby Chris C » Sat May 27, 2006 10:52 pm
Okay, so if I buy LED marker lights, they should already have the resistors in them?
Chris :D
Chris C
Postby Darren » Sat May 27, 2006 10:53 pm
Here's a calculator to figure what resistance you need.
http://led.linear1.org/1led.wiz
Or you can buy LEDs that have the resistor with them. I've had good luck with www.superbrightleds.com
Darren
the camper formerly known as Victor Star
Images: 161
Postby madjack » Sun May 28, 2006 2:27 am
Chris C wrote:Okay, so if I buy LED marker lights, they should already have the resistors in them?
YES............................................................. 8)
Postby Chris C » Sun May 28, 2006 6:57 am
A simple answer to a simple question. Thanks, Madjack. :bowdown:
Chris :D
Chris C
Postby Steve_Cox » Sun May 28, 2006 10:01 am
Chris C wrote:A simple answer to a simple question. Thanks, Madjack. :bowdown:
Not too bad Chris, only 8 responses to your question before getting the answer you were looking for. Some threads that never happens :D
The resistor answers were very informative, but it was a good thing you didn't ask something difficult, like adding an incandescent 3rd brake light to LED tail/turn/stop lights. :crazy:
Steve_Cox
Images: 196
Postby SteveH » Sun May 28, 2006 11:53 am
Hey, It's easy to answer a very specific question....a vague one takes a little more verbage! :lol:
SteveH
SteveH
Images: 42
Return to Electrical Secrets
