Decisions decisions.....
Postby Socal Tom » Tue Mar 24, 2015 10:17 am
So,
I've got my little 5x8 Generic Benroy, and I enjoy it about 4 to 5 weekends per year, but it needs some work to improve a few things.
1) The galley hatch has gaps that will require splicing some wood into the sides to close, and then new T molding around the hatch
2) The hatch was cut into the sides similar to the "fredricks" way, but the cut at the top, is angled under the hinge, and water finds a way in. I don't think there is a clean fix for this
3) The roof is 1 layer of luan, and its been coated with pool deck paint. Id like to remove the luan and replace it, then cover with either EPDM or Aluminum.
4) I think one of my doors is bowed, so I probably need to cut a new door and re-trim.
5) I'm considering covering the sides with FRP to cover some imperfections.
6) I tried to use beadboard for my ceiling, and it was a failure, I need to pull it out and replace it with something that bends without splitting
That having been said, I've used it pretty much as is for 3 years now and it really hasn't been a problem. I'm in Southern CA, and its stored covered so it doesn't see much rain ( one time worth talking about in 3 years)
So I have 3 options
1) Just leave it alone and be happy with it as is. If it starts falling apart or does become a problem, then fix it.
2) Prioritize and perform the repairs above as funds, time and energy permit
3) Start over.... I would really like a 5x9, the time and cost to do the work above probably isn't a lot different that cutting a new set of sidewalls and scrapping the old "cabin" and moving everything over. I can pretty much build the shell on the ground, then swap "cabins" and then transfer the parts when I'm ready. I could even make the doors smaller ( mine are 30 x 36) so that I could swap in commercial doors later when I have money.
So what do you guys think is the best approach? is there another alternative I forgot?
Socal Tom
Re: Decisions decisions.....
Postby Java Jack » Tue Mar 24, 2015 12:10 pm
Leave as is and enjoy while you start a new build. This way, you can enjoy it now and for the future. Then when the new build is done, you have something more in line with what you want and you can sell the benroy to help recover some costs and get someone new into teardroppin.
Best of both worlds.
If you can get it down to 2 options, flip a coin. If you are disappointed in the outcome, then you know what you really want to do.
There are 10 types of people in this world, those that understand binary and those that don't.
Regards,
Java
Proud Owner of a CampInn 560 Ultra
Blog: http://cre8tiveapps.blogspot.com/
Video: https://youtu.be/TLLFt3vzFoA
Sill Images: http://imgur.com/a/EE0zC#0
Java Jack
Postby Vedette » Tue Mar 24, 2015 2:16 pm
Java Jack wrote:Leave as is and enjoy while you start a new build. This way, you can enjoy it now and for the future. Then when the new build is done, you have something more in line with what you want and you can sell the benroy to help recover some costs and get someone new into teardroppin.
Jack just saved me some typing!
That is "exactly" what I would have suggested! :thinking:
Brian
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby dales133 » Tue Mar 24, 2015 3:43 pm
Yea jack nailed it.who knows you may even be able to sell the existing one cheap to someone who can't build there own but are prepared to tinker with it
dales133
Postby Socal Tom » Tue Mar 24, 2015 5:27 pm
You guys are basically selecting option 3. The "cabin" for my TD sits on top of the trailer deck, so by removing a few screws it can be removed and replaced with a different cabin, so I can build the new one on the floor while using the old one, until it's time to swap out the parts I'll be recycling ( or as you suggest I could sell the cabin to someone else.
Socal Tom
